I’ve noticed a strange issue after upgrading several laptops to 25.11
After sleep (s2idle) wifi connection may become unreliable. (not always)
if i run ping - i see significant packet loss, this happens over a couple of minutes, and then fixes itself.
but even after it “fixes itself” if you run ping - there is somewhat around 1% of packet loss.
If at any point you just disconnect and reconnect to the same wifi network - packet loss goes to 0% and everything works fine.
Tested on several wifi networks, on 2 laptops.
Is this some known bug?
