While trying to solve the problem I listed in this, this and this topics I came up with a small activation script:
system.activationScripts.setup.text =
# Check if it's the first time the script ran
if [ -e /etc/nixos/.setup-done ]
then exit
else
# Variables
ghlink="https://github.com/Andy3153"
git="${pkgs.git}/bin/git"
su="${pkgs.su}/bin/su"
# Create folder structure
mkdir -p /home/andy3153/src
cd /home/andy3153/src
mkdir -p hyprland/hyprland-rice
mkdir -p nixos/nixos-rice
mkdir -p nvim/andy3153-init.lua
mkdir -p sh/andy3153-zshrc
# Clone Git repos
$git clone $ghlink/hyprland-rice hyprland/hyprland-rice
$git clone $ghlink/nixos-rice nixos/nixos-rice
$git clone $ghlink/andy3153-init.lua nvim/andy3153-init.lua
$git clone $ghlink/andy3153-zshrc sh/andy3153-zshrc
# Link NixOS configs in their place
rm -r /etc/nixos
ln -s /home/andy3153/src/nixos/nixos-rice/etc/nixos /etc/
# Link home-manager configs in their place
rm -r /home/andy3153/.config/home-manager
ln -s /home/andy3153/src/nixos/nixos-rice/home/andy3153/.config/home-manager/ ~andy3153/.config/
# Install Home Manager for andy3153
$su andy3153 -c "\
nix-channel --add https://github.com/nix-community/home-manager/archive/release-23.05.tar.gz home-manager\
nix-channel --update\
nix-shell \<home-manager\> -A install\
# Make sure andy3153 owns his files
chown -R andy3153:andy3153 /home/andy3153
# Ensure it's the last time the script runs
touch /etc/nixos/.setup-done
fi
See the entire configuration.nix
here.
Upon running nixos-install
, it tries running su
but fails, complaining that it can’t run zsh
(user andy3153
’s default shell). Seeing this keeps repeating itself over and over, even if I change the shell, I decided to chroot into the system.
So I used nixos-enter
, which popped me into the environment of the installed system, but with a pretty large problem. The only commands that were able to run were shell builtins.
Getting out of the live installer and actually booting into the system shows everything works normally, but the nixos-install
command did not run my su
command to install home-manager
for my user, so I consider it incomplete.
I don’t know what to do to fix this issue, can anyone help?
