I have been remapping caps lock to escape since starting nixos, and it has always worked.
Now I updated nixpkgs and suddenly caps lock is caps lock. I found nothing in here nor in the nixpkgs issues.
Current nixpkgs rev: b024ced1aac25639f8ca8fdfc2f8c4fbd66c48ef
Updated nixpkgs rev: adaa24fbf46737f3f1b5497bf64bae750f82942e
This is the configuration I have been using:
services.xserver.xkb = {
layout = "us";
model = "pc104";
options = "caps:escape";
variant = "altgr-intl";
I have always been on GNOME.
I am also experiencing this issue.
EDIT: I seem to have this issue only in vscode, adding
"keyboard.dispatch": "keyCode"
To the vscode settings seems to have resolved the issue.
I think your issue is unrelated.
I’d recommend using keyd for that
here’s how I remap caps to ctrl:
services.keyd = {
keyboards = {
default = {
ids = [ "*" ];
settings = {
main = {
capslock = "layer(control)";
rightcontrol = "rightcontrol";
otherlayer = { };
Looks nice, too.
I switched to udevmon temporarily:
{ pkgs, lib, ... }: {
services.interception-tools =
inherit (pkgs.interception-tools-plugins) caps2esc;
inherit (pkgs) interception-tools;
plugins = [ caps2esc ];
udevmonConfig = lib.strings.toJSON [{
JOB = builtins.concatStringsSep " | " [
"${interception-tools}/bin/intercept -g $DEVNODE"
"${lib.getExe caps2esc} -m 1 -t 0"
"${interception-tools}/bin/uinput -d $DEVNODE"
DEVICE.EVENTS.EV_KEY = [ "KEY_CAPSLOCK" "KEY_ESC" ];
I’m also seeing this issue in the past couple months. My config
services.xserver.xkb.options = "compose:ralt,ctrl:nocaps";
is no longer being propagated in a way that’s used by Gnome. I’m not sure if this is on Nix’s side or Gnome’s side.
If I manually touch the dconf value that Gnome uses here
$ dconf write /org/gnome/desktop/input-sources/xkb-options "['compose:ralt', 'ctrl:nocaps']"
then my Compose key starts functioning again and Caps lock gets disabled as expected.
This used to work fine (though I can’t remember if this dconf value was ever getting set using this configuration system).
I also notice that
$ setxkbmap -print -query
WARNING: Running setxkbmap against an Xwayland server
xkb_keymap {
xkb_keycodes { include "evdev+aliases(qwerty)" };
xkb_types { include "complete" };
xkb_compat { include "complete" };
xkb_symbols { include "pc+us+inet(evdev)" };
xkb_geometry { include "pc(pc105)" };
rules: evdev
model: pc105
layout: us
has no information about this configuration
The conf file does appear to be getting written though
$ cat /etc/X11/xorg.conf.d/00-keyboard.conf
Section "InputClass"
Identifier "Keyboard catchall"
MatchIsKeyboard "on"
Option "XkbModel" "pc104"
Option "XkbLayout" "us"
Option "XkbOptions" "compose:ralt,ctrl:nocaps"
Option "XkbVariant" ""
EndSection
After much nixpkgs bisecting, I’ve determined that this started occurring when the GNOME: 47 → 48 PR was merged.
I haven’t yet been able to bisect which exact commit/package though because the PR was merged without squashing and most (all?) of the intermediate commits fail to build my system due to compilation errors with glib/gtk etc.
I’m very suspicious of this commit to gnome-settings-daemon, though: keyboard: Do not load xkb-options from localed when explicitly set to empty (3a9fce09) · Commits · GNOME / gnome-settings-daemon · GitLab . I notice that my dconf setting for /org/gnome/desktop/input-sources/xkb-options is populating to an empty list:
$ dconf read /org/gnome/desktop/input-sources/xkb-options
@as []
and that commit will make it stop getting written to.
Any update? I just had a fresh install of 25.11 with Gnome and I am facing the same problem.
xkb.options seems to be ignored.
Based on @ignormies dconf idea, I am now setting the home-manager dconf.settings option to
dconf.settings = {
"org/gnome/desktop/input-sources" = {
xkb-options = "caps:escape";
