Surface Pro 4 nixos-hardware nixos-rebuild error
Firstly I apologize. I have read the documentation but am still a noob and I hope this isn’t a dumb issue.
I have been planning to make the jump to NixOS on my Surface Pro 4. Since my hardware is unusual I had been planning to use the nixos-hardware GitHub repository. I recently began my attempt at using the nixos-hardware channel and importing the surface common module in my configuration.nix as presented on the page. Despite my research I have managed to run into an error when I try to use nixos-rebuild and I am still running into trouble.
I searched around on various websites about potential causes of this issue but found none and racked my brain so either its not been encountered previously or I really dropped the ball. The only suspicion I have is that maybe I need to implement this pre-installation instead of post installation but honestly I am stumped.
Edit: Upgraded my kernel to latest version and that did no favors either. The same error occurred.
Any with this is greatly appreciated.
My attempt with nixos-rebuild:
[radocruz@nixos:~]$ sudo nixos-rebuild test
[sudo] password for radocruz:
building Nix...
these 8 derivations will be built:
  /nix/store/gpsrz7zpm8vk4zyffja4lfbywd63iyp8-linux-config-6.0.17.drv
  /nix/store/287sgispsg2wl7w1bgaav4gf4hkjhly9-linux-6.0.17.drv
  /nix/store/c8v25ckni5qlims9aayjmw0ynwnhz05p-kernel-modules.drv
  /nix/store/pik6c4w9k55qb52w22fiyc8gns96zrdh-linux-6.0.17-modules.drv
  /nix/store/hkl8l22fs0znhb4qmhiy3gxmp4kda0gb-linux-6.0.17-modules-shrunk.drv
  /nix/store/i2kmcb2wip69x2r8qrq6qs6qzfnyrvjb-stage-1-init.sh.drv
  /nix/store/gj78a0251li427r9zjq5vr8gh214q17p-initrd-linux-6.0.17.drv
  /nix/store/rsp3l62g08n8gjrjrlrjr7w2hhk9g9j9-nixos-system-nixos-22.11.3567.0040164e473.drv
building '/nix/store/gpsrz7zpm8vk4zyffja4lfbywd63iyp8-linux-config-6.0.17.drv'...
unpacking sources
unpacking source archive /nix/store/3wws6yppyww6fxdl1sdnnchq9pr7apvn-linux-6.0.17.tar.xz
source root is linux-6.0.17
setting SOURCE_DATE_EPOCH to timestamp 1672827992 of file linux-6.0.17/virt/lib/irqbypass.c
patching sources
applying patch /nix/store/mibwk9p63p9pv0ps54s93ycyav20g1k2-source/patches/6.0/0001-surface3-oemb.patch
/nix/store/ifiygfv17dzpbssxwrld6a57iclzrb09-stdenv-linux/setup: line 1002: /nix/store/mibwk9p63p9pv0ps54s93ycyav20g1k2-source/patches/6.0/0001-surface3-oemb.patch: No such file or directory
error: builder for '/nix/store/gpsrz7zpm8vk4zyffja4lfbywd63iyp8-linux-config-6.0.17.drv' failed with exit code 1
error: 1 dependencies of derivation '/nix/store/287sgispsg2wl7w1bgaav4gf4hkjhly9-linux-6.0.17.drv' failed to build
error: 1 dependencies of derivation '/nix/store/c8v25ckni5qlims9aayjmw0ynwnhz05p-kernel-modules.drv' failed to build
error: 1 dependencies of derivation '/nix/store/pik6c4w9k55qb52w22fiyc8gns96zrdh-linux-6.0.17-modules.drv' failed to build
error: 1 dependencies of derivation '/nix/store/hkl8l22fs0znhb4qmhiy3gxmp4kda0gb-linux-6.0.17-modules-shrunk.drv' failed to build
error: 1 dependencies of derivation '/nix/store/i2kmcb2wip69x2r8qrq6qs6qzfnyrvjb-stage-1-init.sh.drv' failed to build
error: 1 dependencies of derivation '/nix/store/gj78a0251li427r9zjq5vr8gh214q17p-initrd-linux-6.0.17.drv' failed to build
error: 3 dependencies of derivation '/nix/store/rsp3l62g08n8gjrjrlrjr7w2hhk9g9j9-nixos-system-nixos-22.11.3567.0040164e473.drv' failed to build
My barebones configuration.nix:
{ config, pkgs, ... }:
  imports =
      <nixos-hardware/microsoft/surface/common>
      ./hardware-configuration.nix
     # "${builtins.fetchGit { url = "https://github.com/NixOS/nixos-hardware.git"; }}/microsoft/surface/common"
  # Bootloader.
  boot.loader.efi.efiSysMountPoint = "/boot/efi";
  # Enable networking
  # Set your time zone.
  time.timeZone = "America/Denver";
  i18n.extraLocaleSettings = {
    LC_ADDRESS = "en_US.UTF-8";
    LC_IDENTIFICATION = "en_US.UTF-8";
    LC_MEASUREMENT = "en_US.UTF-8";
    LC_MONETARY = "en_US.UTF-8";
    LC_NAME = "en_US.UTF-8";
    LC_NUMERIC = "en_US.UTF-8";
    LC_PAPER = "en_US.UTF-8";
    LC_TELEPHONE = "en_US.UTF-8";
    LC_TIME = "en_US.UTF-8";
  # Enable the GNOME Desktop Environment.
  services.xserver.desktopManager.gnome.enable = true;
  # Configure keymap in X11
  services.xserver = {
    layout = "us";
    xkbVariant = "";
  # Enable sound with pipewire.
  sound.enable = true;
  security.rtkit.enable = true;
  services.pipewire = {
    alsa.enable = true;
    alsa.support32Bit = true;
    pulse.enable = true;
    #jack.enable = true;
    #media-session.enable = true;
  users.users.radocruz = {
    isNormalUser = true;
    description = "**** ****";
    packages = with pkgs; [
      firefox
      git
    #  thunderbird
  # Allow unfree packages
  # $ nix search wget
  #  vim # Do not forget to add an editor to edit configuration.nix! The Nano editor is also installed by default.
  #  wget
  # started in user sessions.
  # programs.mtr.enable = true;
  # programs.gnupg.agent = {
  #   enable = true;
  #   enableSSHSupport = true;
  # Enable the OpenSSH daemon.
  # Open ports in the firewall.
  system.stateVersion = "22.11"; # Did you read the comment?
So this can’t work as is if I’m reading correctly.
nixos-hardware is using 6.0.17
And is using the patches from this commit
Which does not have patches for 6.0
Have you tried using 6.1.18?
https://github.com/NixOS/nixos-hardware/tree/master/microsoft/surface/common/kernel/linux-6.1.18
Probably the 6.0 should be removed as upstream removed it and it is an EOL kernel version.
Thank you for this enlightening info.
In the time since the posting of this I had tinkered around with this but must have failed to properly implement it which led me to the incorrect conclusion was doing the wrong thing. I then had tried other avenues which were wrong but helped me learn the system considerably more.
I apologize since I am fairly new to the Nix language. I tried by using the overview of the nix language and the NixOS wiki page for the Linux kernel. I came to nix-hardware expecting it to be automated like the other surface kernel implementations but that is not what NixOS expects of me which is my bad.
Are there any resources or target concepts on the ‘Linux kernel’ or ‘Overview of the Nix Language’ page I should set my focus on so I can properly implement kernel 6.1.18 from the default.nix and patches.nix file?
