Syntax error please help
error:
… while evaluating the attribute ‘config’
     at /nix/var/nix/profiles/per-user/root/channels/nixos/lib/modules.nix:322:9:
      321|         options = checked options;
      322|         config = checked (removeAttrs config [ "_module" ]);
      323|         _module = checked (config._module);
   … while calling the 'seq' builtin
     at /nix/var/nix/profiles/per-user/root/channels/nixos/lib/modules.nix:322:18:
   error: syntax error, unexpected '='
   at /etc/nixos/configuration.nix:138:22:
      137|   # (e.g. man configuration.nix or on https://nixos.org/nixos/options.html.
      138|  system.stateVersion = "24.05"; # Did you read the comment?
      139| }
building Nix…
error:
      139| }
building the system configuration…
error:
… while evaluating the attribute ‘config.system.build.toplevel’
      139| }
You very likely missed a semicolon in the lines before.
I accidentally deleted a ‘[’ in the packages thanks for the help!
