System (Raspberry Pi) crashing when rebuilding
I have a Raspberry Pi 4 running NixOS, but am having issues where the system becomes completely unresponsive when I run nixos-rebuild. I did wonder if the SD card I was using was too slow, but have replaced it with a high-class one to no avail. Not sure how to diagnose what’s happening here—any pointers would be appreciated. Currently having to power off the machine, try again and hope for the best. Often it works after a few goes.
My first guess would be it runs out of memory. Second guess it gets a bit too hot and throttles the cpu.
To diagnose you could run
top
and
while true; do sleep 10; free -h; done
and
while true; do sleep 10; cat /sys/devices/virtual/thermal/thermal_zone0/temp; done
in separate terminals when running nixos-rebuild
Thanks for the help!
Judging from the output of your free command, I think I’m running out of memory:
               total        used        free      shared  buff/cache   available
Mem:           883Mi       331Mi       403Mi       8.0Mi       148Mi       462Mi
Swap:             0B          0B          0B
Swap:             0B          0B          0B
Mem:           883Mi       335Mi       396Mi       8.0Mi       151Mi       458Mi
Swap:             0B          0B          0B
Mem:           883Mi       335Mi       395Mi       8.0Mi       151Mi       458Mi
Swap:             0B          0B          0B
Mem:           883Mi       342Mi       388Mi       8.0Mi       151Mi       451Mi
Swap:             0B          0B          0B
Mem:           883Mi       343Mi       388Mi       8.0Mi       151Mi       450Mi
Swap:             0B          0B          0B
Mem:           883Mi       344Mi       379Mi       8.0Mi       159Mi       448Mi
Swap:             0B          0B          0B
Mem:           883Mi       674Mi        59Mi       8.0Mi       149Mi       119Mi
Swap:             0B          0B          0B
Mem:           883Mi       797Mi        32Mi       8.0Mi        53Mi        22Mi
Swap:             0B          0B          0B
Mem:           883Mi       796Mi        32Mi       8.0Mi        54Mi        21Mi
Swap:             0B          0B          0B
Temperature looks fairly stable:
46738
47712
46738
47712
49173
48686
47712
Can you suggest any steps for reducing memory usage? Or do I just need to add some swap?
Check if your /tmp is mounted on tmpfs or SD card partition. You might need to override boot.tmp.useTmpfs and before that mount /tmp to a disk partition/bind mount for rebuild.
The default for boot.tmp.useTmpfs is false, so they aren’t likely using it. And I mean their pi appears to only have 1G total RAM. You don’t need boot.tmp.useTmpfs to run out of that little memory with a nixos-rebuild.
Swap is unlikely to help. Nix is actively using the memory it’s allocating, and swap is only good for memory that isn’t actively being used. You’ll be thrashing between RAM and swap space, and the performance is going to be so bad that it’s indistinguishable from the crashing you’re already seeing.
Unfortunately the answer is to use a machine with more memory. Now, luckily, you can eval your config on some other x86_64 machine without building it, copy the resulting .drv closure over to the pi, and tell the pi to build that, and the pi won’t have to eval any Nix code. An automated way would be, on any machine with more memory, use nixos-rebuild --build-host pihostname --target-host pihostname switch, which will eval locally but automatically SSH into the pi to build and deploy the build result. There are other tools like deploy-rs or colmena that are designed around this sort of workflow.
Swap would help. But with only (a bit less than) 1GB of memory, swap usage during nixos-rebuild can be hefty. But worth a try. My smallest system - Librem 5 - has 3GB of memory and is capable of running nixos-rebuild including kernel compiles.
That makes sense, thank you! Having some issues with entering the password on the remote system. I think I’ve gotten past that by adding -tt to NIX_SSHOPTS, but the Pi still seems to then be locking up unfortunately. Maybe I just need to invest in one with more RAM!
Raspberry Pi 5 SBC launched with 2.4 GHz Broadcom BCM2712 quad-core Cortex-A76 SoC - CNX Software :partying_face:
