In short I installed NixOS with very basic configuration, installation went fine and bootloader is also installed correctly and works, but only Windows and Restart To UEFI Interface boot options are present.
Possible bug?
configuration.nix
# your system. Help is available in the configuration.nix(5) man page, on
# https://search.nixos.org/options and in the NixOS manual (`nixos-help`).
{ config, lib, pkgs, ... }:
imports =
./hardware-configuration.nix
# Use the systemd-boot EFI boot loader.
# networking.hostName = "nixos"; # Define your hostname.
# Pick only one of the below networking options.
# networking.wireless.enable = true; # Enables wireless support via wpa_supplicant.
networking.networkmanager.enable = true; # Easiest to use and most distros use this by default.
# Set your time zone.
# time.timeZone = "Europe/Amsterdam";
# i18n.defaultLocale = "en_US.UTF-8";
# console = {
# font = "Lat2-Terminus16";
# keyMap = "us";
# useXkbConfig = true; # use xkb.options in tty.
# Configure keymap in X11
# services.xserver.xkb.layout = "us";
# services.xserver.xkb.options = "eurosign:e,caps:escape";
# services.printing.enable = true;
# Enable sound.
sound.enable = true;
hardware.pulseaudio.enable = true;
services.xserver.libinput.enable = true;
users.users.carjin = {
isNormalUser = true;
extraGroups = [ "wheel" ]; # Enable ‘sudo’ for the user.
packages = with pkgs; [
firefox
tree
# $ nix search wget
vim # Do not forget to add an editor to edit configuration.nix! The Nano editor is also installed by default.
wget
nano
# started in user sessions.
# programs.mtr.enable = true;
programs.gnupg.agent = {
enableSSHSupport = true;
# Enable the OpenSSH daemon.
# Open ports in the firewall.
networking.firewall.enable = false;
# Copy the NixOS configuration file and link it from the resulting system
# (/run/current-system/configuration.nix). This is useful in case you
# accidentally delete configuration.nix.
system.copySystemConfiguration = true;
# This option defines the first version of NixOS you have installed on this particular machine,
# and is used to maintain compatibility with application data (e.g. databases) created on older NixOS versions.
# Most users should NEVER change this value after the initial install, for any reason,
# even if you've upgraded your system to a new NixOS release.
# This value does NOT affect the Nixpkgs version your packages and OS are pulled from,
# so changing it will NOT upgrade your system.
# This value being lower than the current NixOS release does NOT mean your system is
# out of date, out of support, or vulnerable.
# Do NOT change this value unless you have manually inspected all the changes it would make to your configuration,
# and migrated your data accordingly.
# For more information, see `man configuration.nix` or https://nixos.org/manual/nixos/stable/options#opt-system.stateVersion .
system.stateVersion = "23.11"; # Did you read the comment?
# Do not modify this file! It was generated by ‘nixos-generate-config’
# and may be overwritten by future invocations. Please make changes
# to /etc/nixos/configuration.nix instead.
{ config, lib, pkgs, modulesPath, ... }:
imports =
[ (modulesPath + "/installer/scan/not-detected.nix")
boot.initrd.availableKernelModules = [ "nvme" "xhci_pci" "usb_storage" "usbhid" "sd_mod" "sdhci_pci" ];
boot.kernelModules = [ "kvm-amd" ];
boot.extraModulePackages = [ ];
fileSystems."/" =
{ device = "/dev/disk/by-uuid/2e880979-0934-43c2-b1dd-5707e900cbf3";
fsType = "btrfs";
options = [ "subvol=@nixos/root" "compress=zstd" ];
fileSystems."/home" =
fsType = "btrfs";
options = [ "subvol=@nixos/home" "compress=zstd"];
fileSystems."/nix" =
fsType = "btrfs";
options = [ "subvol=@nixos/nix" "compress=zstd" "noatime" ];
fileSystems."/boot" =
{ device = "/dev/disk/by-uuid/00D1-7AF3";
fsType = "vfat";
options = [ "fmask=0022" "dmask=0022" ];
swapDevices = [ ];
# Enables DHCP on each ethernet and wireless interface. In case of scripted networking
# (the default) this is the recommended approach. When using systemd-networkd it's
# still possible to use this option, but it's recommended to use it in conjunction
# with explicit per-interface declarations with `networking.interfaces.<interface>.useDHCP`.
networking.useDHCP = lib.mkDefault true;
# networking.interfaces.eno1.useDHCP = lib.mkDefault true;
# networking.interfaces.wlp4s0.useDHCP = lib.mkDefault true;
nixpkgs.hostPlatform = lib.mkDefault "x86_64-linux";
hardware.cpu.amd.updateMicrocode = lib.mkDefault config.hardware.enableRedistributableFirmware;
