I have a preDeviceCommands that prints a message, and powersoff after some time. Since I have LUKS and power-on-ac, this powers off the laptop automatically if no password is input:
boot.initrd.preDeviceCommands = ''
echo -e "Something something" \
| ${pkgs.neo-cowsay}/bin/cowsay --bold --aurora \
&& (sleep 60 && echo "Bye bye..." && poweroff -f &)
Is there any way to achieve the same behaviour (including the message with cowsay), when using systemd on initr (boot.initrd.systemd.enable = true;)?
You could configure the cryptsetup service to poweroff the system if it fails and add a timeout to the LUKS device. Not sure about getting the cowsay part though… Maybe a preStart and set the StandardOutput to the console?
boot.initrd = {
luks.devices.foo.crypttabExtraOpts = [ "timeout=60s" ];
systemd.services."systemd-cryptsetup@" = {
overrideStrategy = "asDropin";
unitConfig.FailureAction = "poweroff";
serviceConfig.StandardOutput = "journal+console";
preStart = ''
echo "Something something" | ${pkgs.neo-cowsay}/bin/cowsay --bold --aurora
systemd.storePaths = [ "${pkgs.neo-cowsay}/bin/cowsay" ];
The slightly more straightforward thing would be a custom service that just does your script (and would be killed by initrd-cleanup.service). But I like doing it with the cryptsetup service’s failure because it’s more representative of what’s actually going on. Only problem is e.g. if cryptsetup actually fails for a non-timeout reason, then the system will just poweroff instead of letting you debug. With a custom service, you could have conflicts = [ "emergency.target" ]; to avoid this.
Thanks! That helped a lot. I done a few small changes and its working great:
boot.initrd = {
serviceConfig = {
TimeoutSec = 90;
unitConfig = {
FailureAction = "poweroff-force";
preStart = ''echo -e "\nSomething Something\n" \
I’ve set the unit timeout instead of using LUKS timeout, because the later would require the device id.
As a short cautionary tale: It is very very important, that storePaths includes the path to cowsay or whatever you are using. I copied my old snippet from pre systemd on initrd over into @abmantis’s config snippet without noticing it using cowsay instead of neo-cowsay.
Thus I had the wrong path in systemd.storePaths which made my system unbootable. I was real scared there for a moment ^^’
Thank god NixOS rollbacks exist
