I have this in my nixos config:
systemd.services."backups" = {
path = [ pkgs.nix ];
script = "/home/user/run_backup.sh";
serviceConfig = {
Type = "oneshot";
User = "user";
systemd.timers."backups" = {
timerConfig = {
OnUnitActiveSec = "12h";
Persistent=true;
Unit = "backups.service";
wantedBy = [ "timers.target" ];
My expectation was that this would run every 12 hours from the last run and write the timestamp of the last run to disk, so that after waking from hibernation, the timer would be triggered again if 12 hours have passed. But from looking at the logs, I’m seeing it only run every 2-3 days, despite me using my laptop a few hours every day.
After reading the docs multiple times, I’m still confused why it’s not working. Could someone please point out what I’m missing?
Yes, but also in the docs for persistent
If true, the time when the service unit was last triggered is stored on disk. When the timer is activated, the service unit is triggered immediately if it would have been triggered at least once during the time when the timer was inactive.
Wouldn’t that make the timer respect passage of wall-clock time when the system isn’t powered on?
I don’t think so. “if it would have been triggered at least once during the time when the timer was inactive” sounds to me like it would not have triggered during suspend time since the monotonic clock was paused.
Okay, thanks I guess that explains the observed behavior. But pretty confusing documentation in my opinion.
The manpage also mentions:
WakeSystem=
Takes a boolean argument. If true, an elapsing timer will
cause the system to resume from suspend, should it be
suspended and if the system supports this. Note that this
option will only make sure the system resumes on the
appropriate times, it will not take care of suspending it
again after any work that is to be done is finished. Defaults
to false.
Note that this functionality requires privileges and is thus
generally only available in the system service manager.
Note that behaviour of monotonic clock timers (as configured
with OnActiveSec=, OnBootSec=, OnStartupSec=,
OnUnitActiveSec=, OnUnitInactiveSec=, see above) is altered
depending on this option. If false, a monotonic clock is used
that is paused during system suspend (CLOCK_MONOTONIC), if
true a different monotonic clock is used that continues
advancing during system suspend (CLOCK_BOOTTIME), see
clock_getres(2) for details.
so either using that or an OnCalendar
timer might get you what you want.
