Hi! I am very new with NixOS. I installed the minimal version and have been having a lot of fun turning on only what I need, as I need it. I am experimenting with hosting some services from a local computer on tailscale. I got an instance of jellyfin working and accessible through tailscale really easily, but immich will not work when trying to access from a remote computer.
I’m familiar working with (non-NixOS) Linux, but not with much networking terminology! I’ve been banging my head against the wall about this for a while. Does anyone have any suggestions, either for a fix or how to gather more information?
information
- Typing in
http://[tailscale ip]:2283from another computer refuses connection. sudo systemctl status immich-serversays it’s running, with the most recent log messageImmich Server is listening on http://[::1]:2283 [v1.123.0] [production]sudo netstat -tunlpn | grep immichgives two entries:
tcp6 0 0 :::34153 :::* LISTEN 1016/immich
tcp6 0 0 ::1:2283 :::* LISTEN 1087/immich-api
wget -i localhost:2283downloads files that look like a functioning web page.- Tailscale doesn’t list the
2283port in the admin dashboard list of services for the machine
- That other port
34153does work from another computer, but just loads a 404 JSON message:{"message":"Cannot GET /","error":"Not Found","statusCode":404}
So it seems like Immich is running happily locally and listening to the correct port, but something fails when trying to access it from another computer.
things I’ve tried
- I rebuilt with
networking.nftables.enable = true;and now instead of refusing connection tohttp://[tailscale ip]:2283, it times out. - I tried disabling jellyfin in case there was a conflict.
- I tried turning magicDNS off.
- I’ve seen a lot of examples that use an additional tool (like caddy or ngnix… a proxy?) to manage this kind of thing. My understanding is that if I want to keep my services locked down to only devices connected to my tailscale network, it’s not necessary. I don’t want to add additional complexity to have to troubleshoot if I don’t have to, and it wasn’t necessary for jellyfin.
- I temporarily opened the port in the firewall with
networking.firewall.allowedTCPPorts = [ 2283 ];, turned off tailscale, and tried connecting with the computer’s wifi IP. The ping went through, but the port still refused. (I think nftables.enable was still set during this test.)
config.nix
Truncated to hide irrelevant lines. Left in comments from the default config about networking that I haven’t ever uncommented because I think I don’t need them or don’t understand them.
networking.hostName = "name"; # Define your hostname.
networking.networkmanager.enable = true; # Easiest to use and most distros use this by default.
# networking.nftables.enable = true;
services.jellyfin = {
user = "admin"; # TODO change this back to default
services.immich = {
# port = 2283;
services.tailscale.enable = true;
services.resolved.enable = true; # possible fix for tailscale?
# $ nix search wget
wget
tailscale
jellyfin
jellyfin-web
jellyfin-ffmpeg
# started in user sessions.
# programs.mtr.enable = true;
# programs.gnupg.agent = {
# enable = true;
# enableSSHSupport = true;
# Enable the OpenSSH daemon.
# Open ports in the firewall.
# networking.firewall.allowedTCPPorts = [ 2283 ];
