Hello, do you have any tips on how to use NixOS with a vertical monitor.
My setup has startx
as my “display manager” along with i3
and use a single monitor 1600x900.
My setup has startx
Look at the services.xserver.xrandrHeads
configuration option. It supports declaring monitors with rotation. You could also keep your script setting up the monitor.
For i3, use services.xserver.windowManager.i3.enable
as stated in the manual.
I use sway (i3, but for Wayland). sway config allows to specify a rotation argument to outputs, like this:
output DP-1 {
mode 1920x1080
transform 90 # for rotatin 90 degrees clockwise
# etc...
For more details, see man 5 sway-output
By the way, if you frequently change monitor setups (e.g a monitor at work and just the laptop screen otherwise), there is a companion daemon called kanshi. It allows to have a separate configuration for each set of outputs, e.g. for the above case:
work {
output "Dell Inc. DELL P2419HC 6LZCJQ2" mode 1920x1080 position 0,0
output eDP-1 position 1920,0
mobile {
output eDP-1
This sets my display at work to be to the left of my laptop screen.
