You were right: sudo nix-channel --list
was still on nixos-23.05
I changed it (remove then add, then update).
But now I get:
[paul@nixos:~]$ sudo nixos-rebuild switch --show-trace
[sudo] password for paul:
building Nix...
error:
… while calling anonymous lambda
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/lib/attrsets.nix:918:24:
917| let f = attrPath:
918| zipAttrsWith (n: values:
919| let here = attrPath ++ [n]; in
… while calling 'g'
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/lib/attrsets.nix:701:19:
700| g =
701| name: value:
702| if isAttrs value && cond value
… from call site
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/lib/attrsets.nix:704:20:
703| then recurse (path ++ [name]) value
704| else f (path ++ [name]) value;
705| in mapAttrs g;
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/lib/modules.nix:242:72:
241| # For definitions that have an associated option
242| declaredConfig = mapAttrsRecursiveCond (v: ! isOption v) (_: v: v.value) options;
243|
… while evaluating the option `system.build.toplevel':
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/lib/modules.nix:822:28:
821| # Process mkMerge and mkIf properties.
822| defs' = concatMap (m:
823| map (value: { inherit (m) file; inherit value; }) (builtins.addErrorContext "while evaluating definitions from `${m.file}':" (dischargeProperties m.value))
… while evaluating definitions from `/nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/nixos/modules/system/activation/top-level.nix':
… from call site
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/lib/modules.nix:823:137:
824| ) defs;
… while calling 'dischargeProperties'
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/lib/modules.nix:894:25:
893| */
894| dischargeProperties = def:
895| if def._type or "" == "merge" then
… from call site
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/nixos/modules/system/activation/top-level.nix:71:12:
70| # Replace runtime dependencies
71| system = foldr ({ oldDependency, newDependency }: drv:
72| pkgs.replaceDependency { inherit oldDependency newDependency drv; }
… while calling 'foldr'
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/lib/lists.nix:53:20:
52| */
53| foldr = op: nul: list:
54| let
… from call site
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/lib/lists.nix:60:8:
59| else op (elemAt list n) (fold' (n + 1));
60| in fold' 0;
61|
… while calling 'fold''
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/lib/lists.nix:56:15:
55| len = length list;
56| fold' = n:
57| if n == len
… from call site
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/nixos/modules/system/activation/top-level.nix:68:10:
67| then throw "\nFailed assertions:\n${concatStringsSep "\n" (map (x: "- ${x}") failedAssertions)}"
68| else showWarnings config.warnings baseSystem;
69|
… while calling 'showWarnings'
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/lib/trivial.nix:414:28:
413|
414| showWarnings = warnings: res: lib.foldr (w: x: warn w x) res warnings;
415|
… from call site
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/lib/trivial.nix:414:33:
413|
415|
52| */
54| let
… from call site
60| in fold' 0;
61|
56| fold' = n:
57| if n == len
… from call site
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/nixos/modules/system/activation/top-level.nix:48:16:
47| # makes it bootable. See `activatable-system.nix`.
48| baseSystem = pkgs.stdenvNoCC.mkDerivation ({
49| name = "nixos-system-${config.system.name}-${config.system.nixos.label}";
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/pkgs/stdenv/generic/make-derivation.nix:598:3:
597| in
598| fnOrAttrs:
599| if builtins.isFunction fnOrAttrs
… while calling 'g'
700| g =
701| name: value:
… from call site
705| in mapAttrs g;
243|
… while evaluating the option `system.systemBuilderArgs':
… from call site
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/lib/modules.nix:844:59:
843| if isDefined then
844| if all (def: type.check def.value) defsFinal then type.merge loc defsFinal
845| else let allInvalid = filter (def: ! type.check def.value) defsFinal;
… while calling 'merge'
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/lib/types.nix:556:20:
555| check = isAttrs;
556| merge = loc: defs:
557| mapAttrs (n: v: v.value) (filterAttrs (n: v: v ? value) (zipAttrsWith (name: defs:
… from call site
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/lib/types.nix:557:35:
558| (mergeDefinitions (loc ++ [name]) elemType defs).optionalValue
… while calling 'filterAttrs'
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/lib/attrsets.nix:381:5:
380| # The attribute set to filter
381| set:
382| listToAttrs (concatMap (name: let v = set.${name}; in if pred name v then [(nameValuePair name v)] else []) (attrNames set));
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/lib/attrsets.nix:382:29:
381| set:
383|
… from call site
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/lib/attrsets.nix:382:62:
381| set:
383|
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/lib/types.nix:557:51:
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/lib/types.nix:557:86:
… while evaluating definitions from `/nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/nixos/modules/system/activation/activatable-system.nix':
… from call site
824| ) defs;
893| */
… from call site
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/nixos/modules/system/activation/activation-script.nix:133:18:
132| apply = set: set // {
133| script = systemActivationScript set false;
134| };
… while calling 'systemActivationScript'
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/nixos/modules/system/activation/activation-script.nix:20:33:
19|
20| systemActivationScript = set: onlyDry: let
21| set' = mapAttrs (_: v: if isString v then (noDepEntry v) // { supportsDryActivation = false; } else v) set;
… from call site
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/nixos/modules/system/activation/activation-script.nix:49:9:
48|
49| ${textClosureMap id (withDrySnippets) (attrNames withDrySnippets)}
50|
… while calling 'textClosureMap'
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/lib/strings-with-deps.nix:75:35:
74|
75| textClosureMap = f: predefined: names:
76| concatStringsSep "\n" (map f (textClosureList predefined names));
… while calling 'id'
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/lib/trivial.nix:14:5:
13| # The value to return
14| x: x;
15|
… while calling 'g'
700| g =
701| name: value:
… from call site
705| in mapAttrs g;
243|
… while evaluating the option `system.activationScripts.etc.text':
… while evaluating definitions from `/nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/nixos/modules/system/etc/etc-activation.nix':
… from call site
824| ) defs;
893| */
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/lib/types.nix:581:29:
580| merge = loc: defs:
581| zipAttrsWith (name: defs:
582| let merged = mergeDefinitions (loc ++ [name]) elemType defs;
… while evaluating definitions from `/nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/nixos/modules/system/etc/etc.nix':
… from call site
824| ) defs;
893| */
… from call site
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/lib/attrsets.nix:160:39:
159| then value
160| else { ${elemAt attrPath n} = atDepth (n + 1); };
161| in atDepth 0;
… while calling 'atDepth'
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/lib/attrsets.nix:157:17:
156| len = length attrPath;
157| atDepth = n:
158| if n == len
… while evaluating derivation 'etc'
whose name attribute is located at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/pkgs/stdenv/generic/make-derivation.nix:348:7
… while evaluating attribute 'buildCommand' of derivation 'etc'
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/pkgs/build-support/trivial-builders/default.nix:87:14:
86| enableParallelBuilding = true;
87| inherit buildCommand name;
88| passAsFile = [ "buildCommand" ]
… from call site
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/nixos/modules/system/etc/etc.nix:54:7:
53| mkdir -p "$out/etc"
54| ${concatMapStringsSep "\n" (etcEntry: escapeShellArgs [
55| "makeEtcEntry"
… while calling 'concatMapStringsSep'
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/lib/strings.nix:117:5:
116| # List of input strings
117| list: concatStringsSep sep (map f list);
118|
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/nixos/modules/system/etc/etc.nix:54:33:
55| "makeEtcEntry"
… from call site
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/nixos/modules/system/etc/etc.nix:54:43:
55| "makeEtcEntry"
118|
… while calling 'escapeShellArg'
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/lib/strings.nix:443:20:
442| */
443| escapeShellArg = arg: "'${replaceStrings ["'"] ["'\\''"] (toString arg)}'";
444|
… while calling 'g'
700| g =
701| name: value:
… from call site
705| in mapAttrs g;
243|
… while evaluating the option `environment.etc.dbus-1.source':
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/lib/modules.nix:844:17:
… from call site
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/lib/modules.nix:844:22:
… while calling 'check'
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/lib/types.nix:509:15:
508| descriptionClass = "noun";
509| check = x: isStringLike x && builtins.substring 0 1 (toString x) == "/";
510| merge = mergeEqualOption;
… while evaluating derivation 'dbus-1'
… while evaluating attribute 'serviceDirectories' of derivation 'dbus-1'
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/pkgs/development/libraries/dbus/make-dbus-conf.nix:18:12:
17| {
18| inherit serviceDirectories suidHelper apparmor;
19| preferLocalBuild = true;
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/lib/types.nix:527:14:
526| merge = loc: defs:
527| map (x: x.value) (filter (x: x ? value) (concatLists (imap1 (n: def:
528| imap1 (m: def':
… from call site
… while evaluating derivation 'system-path'
… while evaluating attribute 'passAsFile' of derivation 'system-path'
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/pkgs/build-support/trivial-builders/default.nix:88:7:
89| ++ (derivationArgs.passAsFile or []);
… while evaluating derivation 'tribler-7.11.0'
… while evaluating attribute 'pythonPath' of derivation 'tribler-7.11.0'
at /nix/store/z78v3yzi5d1rwqgy42zyw4dwvpbs0j22-nixos-23.11/nixos/pkgs/applications/networking/p2p/tribler/default.nix:31:3:
30|
31| pythonPath = [
32| libtorrent
error: asynctest-0.13.0 not supported for interpreter python3.11
[paul@nixos:~]$
I can only guess I need to remove the tribler package.
