Reposting because I realise I forgot a title!! Sorry
My goal is to adjust the speed of one of my desktops case fans based on the temperature of my GPU.
I need to do this because my GPU has no internal fans, and I need to cool it with a custom shroud.
The issue is that the fan can not be detected by lm_sensors
The fan is connected to the motherboard via a 4-pin PWM “chasis fan” header, and I have tried all headers.
I’ve confirmed the fan works via the motherboard BIOS, but it cannot be controlled via nixos. (Fan control through the motherboard isn’t a solution because that doesn’t allow me to monitor the gpu)
Relevant section of my configuration.nix file
I’ve tried with and without each added section
The kernel module nct6775 should support my motherboard (nct6791D)
boot = {
kernelParams = [ "acpi_enfore_resources=lax" ];
kernelModules = [ "coretemp" "nct6775" "wl" ];
extraModprobeConfig = ''
options nct6775 force_id=0x290
extraModulePackages = [ config.boot.kernelPackages.broadcom_sta ];
loader = {
systemd-boot.enable = true;
With and without extraModprobeConfig
force_id=0x209:
[user@nixosserver:~]$ lsmod | grep nct6775
nct6775_core 81920 0
[user@nixosserver:/etc/nixos]$ dmesg | grep nct6775
(no result)
force_id=0 OR taking out extraModprobeConfig:
[user@nixosserver:/etc/nixos]$ lsmod | grep nct6775
nct6775 40960 0
nct6775_core 81920 1 nct6775
hwmon_vid 12288 1 nct6775
Regardless of extraModprobeConfig
Seems to be nothing in /sys/class/hwmon/
From sudo sensors-detect, only interesting result was:
Driver `nct6775':
* ISA bus, address 0x290
Chip `Nuvoton NCT6791D Super IO Sensors' (confidence: 9)
[user@nixosserver:~]$ sudo pwmconfig
# pwmconfig version 3.6.0
This program will search your sensors for pulse width modulation (pwm)
controls, and test each one to see if it controls a fan on
your motherboard. Note that many motherboards do not have pwm
circuitry installed, even if your sensor chip supports pwm.
We will attempt to briefly stop each fan using the pwm controls.
The program will attempt to restore each fan to full speed
after testing. However, it is ** very important ** that you
physically verify that the fans have been to full speed
after the program has completed.
[ 10.311925] nct6775: Found NCT6791D or compatible chip at 0x2e:0x290
[user@nixosserver:/etc/nixos]$ sensors -u
nvme-pci-0300
Adapter: PCI adapter
Composite:
temp1_input: 35.850
temp1_max: 84.850
temp1_min: -273.150
temp1_crit: 84.850
temp1_alarm: 0.000
Sensor 1:
temp2_input: 35.850
temp2_max: 65261.850
temp2_min: -273.150
Sensor 2:
temp3_input: 43.850
temp3_max: 65261.850
temp3_min: -273.150
nouveau-pci-0100
temp1:
temp1_input: 34.000
temp1_max: 95.000
temp1_max_hyst: 3.000
temp1_crit: 105.000
temp1_crit_hyst: 5.000
temp1_emergency: 135.000
temp1_emergency_hyst: 5.000
coretemp-isa-0000
Adapter: ISA adapter
Package id 0:
temp1_input: 39.000
temp1_max: 77.000
temp1_crit: 87.000
temp1_crit_alarm: 0.000
Core 0:
temp2_input: 28.000
temp2_max: 77.000
temp2_crit: 87.000
temp2_crit_alarm: 0.000
Core 1:
temp3_input: 32.000
temp3_max: 77.000
temp3_crit: 87.000
temp3_crit_alarm: 0.000
Core 2:
temp4_input: 27.000
temp4_max: 77.000
temp4_crit: 87.000
temp4_crit_alarm: 0.000
Core 3:
temp5_input: 29.000
temp5_max: 77.000
temp5_crit: 87.000
temp5_crit_alarm: 0.000
Core 4:
temp6_input: 32.000
temp6_max: 77.000
temp6_crit: 87.000
temp6_crit_alarm: 0.000
Core 5:
temp7_input: 28.000
temp7_max: 77.000
temp7_crit: 87.000
temp7_crit_alarm: 0.000
Core 6:
temp8_input: 26.000
temp8_max: 77.000
temp8_crit: 87.000
temp8_crit_alarm: 0.000
Core 7:
temp9_input: 27.000
temp9_max: 77.000
temp9_crit: 87.000
temp9_crit_alarm: 0.000
Computer Specs:
Cpu: Intel(R) Xeon(R) E5-2630 v3 @ 2.40GHz
Motherboard: X99-Deluxe-Series
Ram: 1 stick of 8GB DDR4
Gpu: Attempted with AMD radeon instinct mi50 & nvidia gtx 1050ti
NixOS: 24.05.7376.b134951a4c9f (Uakari)
Kernal: 6.6.68
Any help would be greatly appreciated thanks
If this is a lost cause, any other solutions would be great as well, I’m not set on using lmsensors
