I’ve installed NixOS onto a flash drive that I’d like to turn into a bootable usb, however when I try to boot into it there aren’t any generations to choose from, the only option on the bootloader is to return to my uefi firmware settings
Currently I’m trying to use nixos-rebuild switch under chroot (specifically the nixos-enter command) to create a new generation to boot into, but I’m running into this error whenever I try to build my config:
“System has not been booted with systemd as init system (PID 1). Can’t operate.
Failed to connect to bus: Host is down”
The output from ps aux shows that systemd is my init system:
USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND
root 1 0.0 0.0 22552 14244 ? Ss Apr24 0:02 /run/current-system/systemd/lib/systemd/systemd
Any ideas for this? Thanks
