Even if the script is completely empty or is just exit 0
, the output of journalctl -ze | grep udev
is always “Process ‘script’ failed with exit code 1.”
The udev rule as written in /nix/store/...-udev-rules/99-local.rules
is
ACTION=="change", KERNEL=="card[0-9]*", SUBSYSTEM=="drm", RUN+="script"
configuration.nix
# your system. Help is available in the configuration.nix(5) man page
{ config, pkgs, ... }:
imports =
./hardware-configuration.nix
# Bootloader.
boot.loader.grub.enable = true;
boot.loader.grub.device = "/dev/vda";
boot.loader.grub.useOSProber = true;
# networking.wireless.enable = true; # Enables wireless support via wpa_supplicant.
# Enable networking
# Set your time zone.
time.timeZone = "America/Los_Angeles";
i18n.extraLocaleSettings = {
LC_ADDRESS = "en_US.UTF-8";
LC_IDENTIFICATION = "en_US.UTF-8";
LC_MEASUREMENT = "en_US.UTF-8";
LC_MONETARY = "en_US.UTF-8";
LC_NAME = "en_US.UTF-8";
LC_NUMERIC = "en_US.UTF-8";
LC_PAPER = "en_US.UTF-8";
LC_TELEPHONE = "en_US.UTF-8";
LC_TIME = "en_US.UTF-8";
# Configure keymap in X11
services.xserver = {
layout = "us";
xkbVariant = "";
libinput.enable = true;
videoDrivers = [ "qxl" ];
displayManager.session = [
manage = "desktop";
name = "kitty";
start = ''
/run/current-system/sw/bin/kitty --title kitty &
waitPID=$!
displayManager.autoLogin.enable = true;
displayManager.autoLogin.user = "flat";
displayManager.defaultSession = "kitty";
services.spice-vdagentd.enable = true;
users.users.user = {
isNormalUser = true;
description = "user";
packages = with pkgs; [];
# Enable automatic login for the user.
services.getty.autologinUser = "user";
# Allow unfree packages
# $ nix search wget
# vim # Do not forget to add an editor to edit configuration.nix! The Nano editor is also installed by default.
# wget
pkgs.kitty
pkgs.xdotool
pkgs.xorg.xrandr
(pkgs.writeScriptBin "script" ''
#!/bin/bash
date >> /var/log/script.log
xrandr --output Virtual-1 --auto
xdotool search --class "kitty" windowsize $(xrandr | awk '/current/ {gsub(/,/, ""); print $8, $10}')
# started in user sessions.
# programs.mtr.enable = true;
# programs.gnupg.agent = {
# enable = true;
# enableSSHSupport = true;
# Enable the OpenSSH daemon.
# Open ports in the firewall.
networking.firewall.allowedTCPPorts = [ 30100 ];
networking.firewall.allowedUDPPorts = [ 30100 ];
system.stateVersion = "23.11"; # Did you read the comment?
# Custom
boot.readOnlyNixStore = false;
services.udev.path = [ "/run/current-system/sw/bin" ];
# services.udev.extraRules = ''ACTION=="change", KERNEL=="card[0-9]*", SUBSYSTEM=="drm", RUN+="/run/current-system/sw/bin/script"'';
# services.udev.extraRules = "ACTION==change, KERNEL==card[0-9]*, SUBSYSTEM==drm, RUN+=script";
services.udev.extraRules = "ACTION=='change', KERNEL=='card[0-9]*', SUBSYSTEM=='drm', RUN+='script'";
# ACTION=="change", KERNEL=="card[0-9]*", SUBSYSTEM=="drm", RUN+="/run/current-system/sw/bin/script"
The system is running 23.11.3326.d2003f2223cb (Tapir) inside Proxmox VE 8.1.3.
Sidenote: I can only build with services.udev.extraRules without failure by using the syntax services.udev.extraRules = "ACTION=='change', KERNEL=='card[0-9]*', SUBSYSTEM=='drm', RUN+='script'";
. However, the single-quote strings is not valid syntax for udev. I would also appreciate help with this issue. As of this moment I am manually editing the store for the udev-rules and reloading.
Thanks!
