Unable to Compile Go Code with SQLite Dependencies in Nix Flake Shell
I have a simple Nix Flake shell with the SQLite dependencies required to access the database, but I am unable to compile the code due to the following error:
go build -o ocean-market cmd/main.go
# runtime/cgo
flag provided but not defined: -E
Go is a tool for managing Go source code.
Usage:
	go <command> [arguments]
my nix flake is
  description = "PoC";
    nixpkgs.url = "github:nixos/nixpkgs";
    gomod2nix = {
      url = "github:tweag/gomod2nix";
      inputs.utils.follows = "utils";
  outputs = { self, nixpkgs, flake-utils, gomod2nix }:
        pkgs = import nixpkgs {
          inherit system;
          overlays = [ gomod2nix.overlays.default ];
        packages = {
          default = pkgs.gnumake;
        formatter = pkgs.nixpkgs-fmt;
        devShell = pkgs.mkShell {
          buildInputs = with pkgs; [
            gnumake
            gcc
            glibc.dev
            go
            gopls
            gotools
            go-tools
            gomod2nix.packages.${system}.default
            golangci-lint
            protobuf3_20
          buildPhase = "make";
          shellHook = ''
            export CGO_ENABLED=1
            export PATH=$GOROOT/bin:$GOPATH/bin:$PATH
            make dep
What does which go return inside the shell?
[vincent@vincenzopalazzo-arch-dev]$ which go
/bin/go
I think this is wrong right? I need to set any env variable?
However, nothing change with the following diff
--- a/flake.nix
+++ b/flake.nix
@@ -43,8 +43,9 @@
           shellHook = ''
+            # Ensure the Go binary from Nix is used
+            export PATH=${pkgs.go}/bin:$PATH
-            export PATH=$GOROOT/bin:$GOPATH/bin:$PATH
             make dep
You shouldn’t need to do any of this. nix develop (and other nix commands) prepend your PATH with the store locations of your various packages. Most likely $GOROOT is not set inside the dev shell so your PATH ends up being prepended with just /bin.
I’m also confused by the error message. There was no -E flag passed to your command, yet the error complains about that flag. I initially thought that you had it set in a shell alias for the go command, but it is visibly not the case.
IDK I am just using the sqllite library and I think this is the library that use the flag, so I have no idea on how to fix this
