Unable to ergonomically re-load R code in nix
Issue:-
  • Aberrant behaviour with an R package when working in a Nix system, specifically coding and reloading the package is not working and produces errors. I need to restart my IDE to evaluate the changes I have made to the code.
Expected outcome:-
  • Be able to change my R-code interacting with the R package and not need to re-start my IDE everytime I make a change.
Details:-
  • Nix version:- 24.05
  • R-shiny (the relevant r package):- 1.8.0
I am using the rPackages.Shiny package available here nixpkgs/pkgs/development/r-modules/generic-builder.nix at 9256f7c71a195ebe7a218043d9f93390d49e6884 · NixOS/nixpkgs · GitHub . I am using it as it without any changes of my own.
Here is what my the relevant section of my config looks like:-
      RStudio-with-my-packages = rstudioWrapper.override{
        packages = with rPackages; [
          ggplot2
          ggtree
          igraph
          ggpubr
          dplyr
          shiny
          tidyverse
          bigsnpr
          data_table
          bslib
          svglite
          ggExtra
          ape
          phylotools
          argparse
          rPackages.IRkernel
          rPackages.languageserver
I am trying to build a Shiny App for my employer and playing with sample code from the Shiny tutorial available here:-
library(shiny)
# Define UI ----
ui <- page_fluid(
  titlePanel("Basic widgets"),
  layout_columns(
    col_width = 3,
    card(
      card_header("Buttons"),
      actionButton("action", "Action"),
      submitButton("Submit")
    card(
      card_header("Single checkbox"),
      checkboxInput("checkbox", "Choice A", value = TRUE)
    card(
      card_header("Checkbox group"),
      checkboxGroupInput(
        "checkGroup",
        "Select all that apply",
        choices = list("Choice 1" = 1, "Choice 2" = 2, "Choice 3" = 3),
        selected = 1
    card(
      card_header("Date input"),
      dateInput("date", "Select date", value = "2014-01-01")
    card(
      card_header("Date range input"),
      dateRangeInput("dates", "Select dates")
    card(
      card_header("File input"),
      fileInput("file", label = NULL)
    card(
      card_header("Help text"),
      helpText(
        "Note: help text isn't a true widget,",
        "but it provides an easy way to add text to",
        "accompany other widgets."
    card(
      card_header("Numeric input"),
      numericInput("num", "Input number", value = 1)
    card(
      card_header("Radio buttons"),
      radioButtons(
        "radio",
        "Select option",
        selected = 1
    card(
      card_header("Select box"),
      selectInput(
        "select",
        "Select option",
        selected = 1
    card(
      card_header("Sliders"),
      sliderInput(
        "slider1",
        "Set value",
        min = 0,
        max = 100,
        value = 50
      sliderInput(
        "slider2",
        "Set value range",
        min = 0,
        max = 100,
        value = c(25, 75)
    card(
      card_header("Text input"),
      textInput("text", label = NULL, value = "Enter text...")
# Define server logic ----
server <- function(input, output) {
# Run the app ----
shinyApp(ui = ui, server = server)
The code produces a working output the first time around but everytime I make a change and reaload the app, I get the following error:-
Warning in file.copy(script, dirname(outfile), overwrite = TRUE) :
  problem copying /nix/store/m81gr51dvwn9bd2b6w5gzy0qsnm36cwv-r-shiny-1.8.0/library/shiny/www/shared/selectize//js/selectize.min.js to /tmp/RtmpHhtDgJ/selectize6266c6e8c47f24e0f16990664c14d764/selectize.min.js: Permission denied
  problem copying /nix/store/m81gr51dvwn9bd2b6w5gzy0qsnm36cwv-r-shiny-1.8.0/library/shiny/www/shared/selectize//accessibility/js/selectize-plugin-a11y.min.js to /tmp/RtmpHhtDgJ/selectize6266c6e8c47f24e0f16990664c14d764/selectize-plugin-a11y.min.js: Permission denied
Warning: Error in bslib::bs_dependency: Failed to copy the following script(s): /nix/store/m81gr51dvwn9bd2b6w5gzy0qsnm36cwv-r-shiny-1.8.0/library/shiny/www/shared/selectize//js/selectize.min.js, /nix/store/m81gr51dvwn9bd2b6w5gzy0qsnm36cwv-r-shiny-1.8.0/library/shiny/www/shared/selectize//accessibility/js/selectize-plugin-a11y.min.js.
Make sure script are absolute path(s).
My best guess is that I am stuck somewhere between Nix and R not meshing well with each other - but I am not being able to figure out how to solve it or it it can be solved without working with the underlying Nix config for the package (not sure if that is the jargon for the rPackage.Shiny code).
What can I do to debug this issue?
If you cp that bootstrap.min.css file to the same location you get that same permissions error.
# Succeeds
cp /nix/store/3fxl93ds7a9ad0b4s64dqhbcd2ay85ny-r-shiny-1.9.1/library/shiny/www/shared/selectize//js/selectize.min.js .
# Fails
cp: cannot create regular file './selectize.min.js': Permission denied
So this is just one of those nix things you have to work around sometimes. I presume this is by design, but I’m not 100% sure the reason. The fix is to set the theme to a location that’s not in the nix store. That file won’t have the same restrictions as what’s being copied from /nix.
library(shiny)
library(bslib)
options(shiny.autoreload = TRUE)
# Copy the compiled css theme to your project folder.
file.copy(precompiled_css_path(theme = bs_theme()), "./bootstrap.min.css")
# Define UI ----
ui <- bslib:::page_fluid(
  theme = "bootstrap.min.css",
Not the prettiest, but works for development.
I see! Thank you for pointing that out.
I am a complete beginner to Nix and still not quite there with being able to grok these issues out just yet - so I appreciate your help.
