What happens when I launch SteamVR. I see the following: Image link
My Valve Index remains completely black (nothing shows in the lenses), though the headset’s blue front lights are on. The device is recognized through lsbusb as well:
$ lsusb | grep Valve
Bus 006 Device 003: ID 28de:2400 Valve Software 3D Camera
Bus 005 Device 008: ID 28de:2102 Valve Software Valve VR Radio & HMD Mic
Bus 005 Device 007: ID 28de:2102 Valve Software Valve VR Radio
Bus 005 Device 006: ID 28de:2300 Valve Software Index HMD
Bus 005 Device 003: ID 28de:2613 Valve Software
System info.
- I’m running NixOS against channel
nixos-21.05. (I’ve also triednixos-unstable, which has the same behavior). - I have an nvidia GPU using drivers
services.xserver.videoDrivers = [ "nvidia" ]; - In my
configuration.nix, I havesteamandsteam-runadded to my list of installed programs, with:
hardware.opengl.driSupport32Bit = true;
hardware.steam-hardware.enable = true;
programs.steam.enable = true;
Sometimes I get SteamVR room setup. Sometimes I get the “SteamVR Room Setup” window popping up, which claims it can’t detect the headset (despite the headset showing it’s detected in the STEAMVR status popup): https://i.imgur.com/fCtXAOf.png
I can’t boot NixOS with the headset plugged in. If I start NixOS with the Valve Index plugged in, I just get a black screen/can’t get NixOS to start. Note that nothing shows up in the Valve Index when I start up either (i.e. the BIOS window isn’t moving to the Valve Index as its monitor). So in all of these cases, I am attempting to get the Valve Index to work by plugging it in after NixOS has already booted up.
Steam info. I’m running SteamVR in non-beta.
/tmp/SteamVRLauncherSetup.log.
Wed Sep 8 17:48:59 CDT 2021 - Error: setcap of vrcompositor-launcher failed.
Steam logs.
vrclient_vrcompositor.txt
Wed Sep 08 2021 17:49:03.537661 - App key after connect message:openvr.component.vrcompositor
Wed Sep 08 2021 17:49:03.539427 - Initializing the limited version of CVRCompositorClient
Wed Sep 08 2021 17:49:06.411679 - //==============================================================================================
Wed Sep 08 2021 17:49:06.411694 - ================================================================================================
Wed Sep 08 2021 17:49:06.411700 - ================================================================================================
Wed Sep 08 2021 17:49:06.411709 - vrcompositor 1.19.7 startup with PID=5011, config=/home/user/.local/share/Steam/config, runtime=/home/user/.local/share/Steam/steamapps/common/SteamVR
Wed Sep 08 2021 17:49:06.411727 - vrclient type=VRApplication_Background
Wed Sep 08 2021 17:49:06.412038 - [Settings] Load Default Json Settings from /home/user/.local/share/Steam/steamapps/common/SteamVR/drivers/htc/resources/settings/default.vrsettings
Wed Sep 08 2021 17:49:06.412063 - [Settings] Load Default Json Settings from /home/user/.local/share/Steam/steamapps/common/SteamVR/drivers/lighthouse/resources/settings/default.vrsettings
Wed Sep 08 2021 17:49:06.412085 - [Settings] Load Default Json Settings from /home/user/.local/share/Steam/steamapps/common/SteamVR/drivers/null/resources/settings/default.vrsettings
Wed Sep 08 2021 17:49:06.412171 - [Settings] Load Default Json Settings from /home/user/.local/share/Steam/steamapps/common/SteamVR/resources/settings/default.vrsettings
Wed Sep 08 2021 17:49:06.412359 - [Settings] Load Json Settings from /home/user/.local/share/Steam/config/steamvr.vrsettings
Wed Sep 08 2021 17:49:06.417050 - CIPCPipe::ConnectPipe(SteamVR_Namespace) attempting connect to steamvr:SteamVR_Namespace
Wed Sep 08 2021 17:49:06.417097 - CSharedResourceNamespaceClient::Init(): received namespace data 4722
Wed Sep 08 2021 17:49:06.417112 - CIPCPipe::ConnectPipe(VR_ServerPipe_4722) attempting connect to steamvr:VR_ServerPipe_4722
Wed Sep 08 2021 17:49:06.417785 - Received success response from vrserver connect
Wed Sep 08 2021 17:49:06.418648 - App key after connect message:openvr.component.vrcompositor
Wed Sep 08 2021 17:49:06.420387 - Initializing the limited version of CVRCompositorClient
Wed Sep 08 2021 22:01:31.883788 - //==============================================================================================
Wed Sep 08 2021 22:01:31.883861 - ================================================================================================
Wed Sep 08 2021 22:01:31.883867 - ================================================================================================
Wed Sep 08 2021 22:01:31.883876 - vrcompositor 1.19.7 startup with PID=47256, config=/home/user/.local/share/Steam/config, runtime=/home/user/.local/share/Steam/steamapps/common/SteamVR
Wed Sep 08 2021 22:01:31.883898 - vrclient type=VRApplication_Background
Wed Sep 08 2021 22:01:31.884214 - [Settings] Load Default Json Settings from /home/user/.local/share/Steam/steamapps/common/SteamVR/drivers/htc/resources/settings/default.vrsettings
Wed Sep 08 2021 22:01:31.884240 - [Settings] Load Default Json Settings from /home/user/.local/share/Steam/steamapps/common/SteamVR/drivers/lighthouse/resources/settings/default.vrsettings
Wed Sep 08 2021 22:01:31.884262 - [Settings] Load Default Json Settings from /home/user/.local/share/Steam/steamapps/common/SteamVR/drivers/null/resources/settings/default.vrsettings
Wed Sep 08 2021 22:01:31.884350 - [Settings] Load Default Json Settings from /home/user/.local/share/Steam/steamapps/common/SteamVR/resources/settings/default.vrsettings
Wed Sep 08 2021 22:01:31.884533 - [Settings] Load Json Settings from /home/user/.local/share/Steam/config/steamvr.vrsettings
Wed Sep 08 2021 22:01:31.889826 - CIPCPipe::ConnectPipe(SteamVR_Namespace) attempting connect to steamvr:SteamVR_Namespace
Wed Sep 08 2021 22:01:31.889861 - CSharedResourceNamespaceClient::Init(): received namespace data 47138
Wed Sep 08 2021 22:01:31.889876 - CIPCPipe::ConnectPipe(VR_ServerPipe_47138) attempting connect to steamvr:VR_ServerPipe_47138
Wed Sep 08 2021 22:01:31.891231 - Received success response from vrserver connect
Wed Sep 08 2021 22:01:31.892078 - App key after connect message:openvr.component.vrcompositor
Wed Sep 08 2021 22:01:31.893632 - Initializing the limited version of CVRCompositorClient
Wed Sep 08 2021 22:01:34.867174 - //==============================================================================================
Wed Sep 08 2021 22:01:34.867189 - ================================================================================================
Wed Sep 08 2021 22:01:34.867195 - ================================================================================================
Wed Sep 08 2021 22:01:34.867203 - vrcompositor 1.19.7 startup with PID=47522, config=/home/user/.local/share/Steam/config, runtime=/home/user/.local/share/Steam/steamapps/common/SteamVR
Wed Sep 08 2021 22:01:34.867222 - vrclient type=VRApplication_Background
Wed Sep 08 2021 22:01:34.867523 - [Settings] Load Default Json Settings from /home/user/.local/share/Steam/steamapps/common/SteamVR/drivers/htc/resources/settings/default.vrsettings
Wed Sep 08 2021 22:01:34.867546 - [Settings] Load Default Json Settings from /home/user/.local/share/Steam/steamapps/common/SteamVR/drivers/lighthouse/resources/settings/default.vrsettings
Wed Sep 08 2021 22:01:34.867567 - [Settings] Load Default Json Settings from /home/user/.local/share/Steam/steamapps/common/SteamVR/drivers/null/resources/settings/default.vrsettings
Wed Sep 08 2021 22:01:34.867650 - [Settings] Load Default Json Settings from /home/user/.local/share/Steam/steamapps/common/SteamVR/resources/settings/default.vrsettings
Wed Sep 08 2021 22:01:34.867831 - [Settings] Load Json Settings from /home/user/.local/share/Steam/config/steamvr.vrsettings
Wed Sep 08 2021 22:01:34.872726 - CIPCPipe::ConnectPipe(SteamVR_Namespace) attempting connect to steamvr:SteamVR_Namespace
Wed Sep 08 2021 22:01:34.872781 - CSharedResourceNamespaceClient::Init(): received namespace data 47138
Wed Sep 08 2021 22:01:34.872795 - CIPCPipe::ConnectPipe(VR_ServerPipe_47138) attempting connect to steamvr:VR_ServerPipe_47138
Wed Sep 08 2021 22:01:34.873468 - Received success response from vrserver connect
Wed Sep 08 2021 22:01:34.874314 - App key after connect message:openvr.component.vrcompositor
Wed Sep 08 2021 22:01:34.876307 - Initializing the limited version of CVRCompositorClient
vrserver.txt
Wed Sep 08 2021 22:01:59.472423 - lighthouse: Selected existing universe 1631141181 (C05F1EA4 is primary)
Wed Sep 08 2021 22:01:59.472429 - lighthouse: Setting universe tilt from C05F1EA4 via transform to global: pitch -1.13 deg roll -0.76 deg
Wed Sep 08 2021 22:01:59.477273 - lighthouse: Saved LighthouseDB rev 9 to /home/user/.local/share/Steam/config/lighthouse/lighthousedb.json
Wed Sep 08 2021 22:01:59.477385 - Failed to read chaperone file from /home/user/.local/share/Steam/config/chaperone_info.vrchap
Wed Sep 08 2021 22:01:59.479552 - 0 - leaving standby
Wed Sep 08 2021 22:01:59.497697 - [OnMsg_LaunchApplication( openvr.tool.steamvr_room_setup )] from vrmonitor (47313)
Wed Sep 08 2021 22:01:59.517300 - SetApplicationPid appkey=openvr.tool.steamvr_room_setup pid=48214, external transition
Wed Sep 08 2021 22:01:59.517359 - SetApplicationPid: Setting app openvr.tool.steamvr_room_setup PID to 48214
Wed Sep 08 2021 22:01:59.517409 - Processing message VRMsg_LaunchApplication from vrmonitor (47313) took 0.0197 seconds
Wed Sep 08 2021 22:01:59.894803 - CSharedResourceNamespaceServer sent namespace data: 47138
Wed Sep 08 2021 22:01:59.894941 - Rejecting vrclient connection from /home/user/.local/share/Steam/steamapps/common/SteamVR/tools/steamvr_room_setup/linux64/steamvr_room_setup with client DLL "/home/user/.local/share/Steam/steamapps/common/SteamVR/bin/linux64/vrclient.so" (v1.19.7)
Wed Sep 08 2021 22:01:59.895259 - New Connect message from /home/user/.local/share/Steam/steamapps/common/SteamVR/tools/steamvr_room_setup/linux64/steamvr_room_setup (VRApplication_Scene) (Args: -popupwindow) 48214
Wed Sep 08 2021 22:01:59.895274 - StartSceneApplicationTransitionFromProcess( 48214, /home/user/.local/share/Steam/steamapps/common/SteamVR/tools/steamvr_room_setup/linux64/steamvr_room_setup, openvr.tool.steamvr_room_setup)
Wed Sep 08 2021 22:01:59.895279 - AppInfoManager.ProcessConnected BEGIN 48214 /home/user/.local/share/Steam/steamapps/common/SteamVR/tools/steamvr_room_setup/linux64/steamvr_room_setup 1 openvr.tool.steamvr_room_setup
Wed Sep 08 2021 22:01:59.895286 - SetApplicationPid appkey=openvr.tool.steamvr_room_setup pid=48214, external transition
Wed Sep 08 2021 22:01:59.895292 - SetApplicationPid: Setting app openvr.tool.steamvr_room_setup PID to 48214
Wed Sep 08 2021 22:01:59.895326 - AppInfoManager.ProcessConnected END
Wed Sep 08 2021 22:01:59.895459 - Enabling legacy input for openvr.tool.steamvr_room_setup
Wed Sep 08 2021 22:01:59.895980 - openvr.tool.steamvr_room_setup (indexhmd) attempting to load default config from file:///home/user/.local/share/Steam/steamapps/common/SteamVR/resources/config/legacy_bindings_generic_hmd.json
Wed Sep 08 2021 22:01:59.895996 - Using existing HMD lighthouse.LHR-B48E1E6F
Wed Sep 08 2021 22:02:10.491996 - Socket closed
Wed Sep 08 2021 22:02:10.492019 - Unable to read message from socket: 0
Wed Sep 08 2021 22:02:10.492034 - Process steamvr_room_setup (48214) disconnected (Thread(0x0x7fda8c007d40/0x0x7f)
Wed Sep 08 2021 22:02:10.492046 - AppInfoManager.ProcessQuit processid=48214 eLaunchingApp=LaunchingApp_None
Wed Sep 08 2021 22:02:10.492053 - AppInfoManager.ProcessQuit: Clearing application openvr.tool.steamvr_room_setup PID was 48214
Wed Sep 08 2021 22:02:10.492059 - AppInfoManager.ProcessQuit: Clearing application openvr.tool.steamvr_room_setup PID because 48214 has exited
Wed Sep 08 2021 22:02:10.518334 - CSharedResourceNamespaceServer sent namespace data: 47138
Wed Sep 08 2021 22:02:10.518448 - Rejecting vrclient connection from /home/user/.local/share/Steam/steamapps/common/SteamVR/tools/steamvr_room_setup/linux64/steamvr_room_setup with client DLL "/home/user/.local/share/Steam/steamapps/common/SteamVR/bin/linux64/vrclient.so" (v1.19.7)
Wed Sep 08 2021 22:02:10.518561 - Unable to create property container PC_70000bc56 because it already existed
Wed Sep 08 2021 22:02:10.518568 - Unable to create property container for steamvr_room_setup (48214). Maybe it's a reconnect?
Wed Sep 08 2021 22:02:10.518580 - New Connect message from /home/user/.local/share/Steam/steamapps/common/SteamVR/tools/steamvr_room_setup/linux64/steamvr_room_setup (VRApplication_Scene) (Args: -popupwindow) 48214
Wed Sep 08 2021 22:02:10.518589 - StartSceneApplicationTransitionFromProcess( 48214, /home/user/.local/share/Steam/steamapps/common/SteamVR/tools/steamvr_room_setup/linux64/steamvr_room_setup, openvr.tool.steamvr_room_setup)
Wed Sep 08 2021 22:02:10.518595 - AppInfoManager.ProcessConnected BEGIN 48214 /home/user/.local/share/Steam/steamapps/common/SteamVR/tools/steamvr_room_setup/linux64/steamvr_room_setup 1 openvr.tool.steamvr_room_setup
Wed Sep 08 2021 22:02:10.518600 - SetApplicationPid appkey=openvr.tool.steamvr_room_setup pid=48214, external transition
Wed Sep 08 2021 22:02:10.518605 - SetApplicationPid: Setting app openvr.tool.steamvr_room_setup PID to 48214
Wed Sep 08 2021 22:02:10.518640 - AppInfoManager.ProcessConnected END
Wed Sep 08 2021 22:02:10.518792 - Enabling legacy input for openvr.tool.steamvr_room_setup
Wed Sep 08 2021 22:02:10.518921 - openvr.tool.steamvr_room_setup (indexhmd) attempting to load default config from file:///home/user/.local/share/Steam/steamapps/common/SteamVR/resources/config/legacy_bindings_generic_hmd.json
Wed Sep 08 2021 22:02:10.518935 - Using existing HMD lighthouse.LHR-B48E1E6F
Wed Sep 08 2021 22:02:15.527455 - 0 - entering standby
Wed Sep 08 2021 22:02:21.118295 - Socket closed
Wed Sep 08 2021 22:02:21.118320 - Unable to read message from socket: 0
Wed Sep 08 2021 22:02:21.118334 - Process steamvr_room_setup (48214) disconnected (Thread(0x0x7fda8c00a180/0x0x7f)
Wed Sep 08 2021 22:02:21.118342 - 0 - leaving standby
Wed Sep 08 2021 22:02:21.120356 - AppInfoManager.ProcessQuit processid=48214 eLaunchingApp=LaunchingApp_None
Wed Sep 08 2021 22:02:21.120366 - AppInfoManager.ProcessQuit: Clearing application openvr.tool.steamvr_room_setup PID was 48214
Wed Sep 08 2021 22:02:21.120373 - AppInfoManager.ProcessQuit: Clearing application openvr.tool.steamvr_room_setup PID because 48214 has exited
Wed Sep 08 2021 22:02:24.107247 - lighthouse: LHR-B48E1E6F: Updated IMU calibration: Accel bias change 0.03m/s/s
Wed Sep 08 2021 22:02:24.115668 - lighthouse: Saved LighthouseDB rev 10 to /home/user/.local/share/Steam/config/lighthouse/lighthousedb.json
Wed Sep 08 2021 22:02:26.122881 - 0 - entering standby
vrcompositor.txt
Wed Sep 08 2021 22:01:34.905544 - - VK_LAYER_NV_optimus, version 4202671
Wed Sep 08 2021 22:01:34.905550 - - VK_LAYER_VALVE_steam_fossilize_32, version 4202632
Wed Sep 08 2021 22:01:34.905555 - - VK_LAYER_VALVE_steam_overlay_32, version 4202632
Wed Sep 08 2021 22:01:34.905560 - - VK_LAYER_VALVE_steam_overlay_64, version 4202632
Wed Sep 08 2021 22:01:34.905564 - - VK_LAYER_VALVE_steam_fossilize_64, version 4202632
Wed Sep 08 2021 22:01:34.921732 - Instance extensions available:
Wed Sep 08 2021 22:01:34.921754 - - VK_KHR_device_group_creation, version 1
Wed Sep 08 2021 22:01:34.921766 - - VK_KHR_display, version 23
Wed Sep 08 2021 22:01:34.921776 - - VK_KHR_external_fence_capabilities, version 1
Wed Sep 08 2021 22:01:34.921785 - - VK_KHR_external_memory_capabilities, version 1
Wed Sep 08 2021 22:01:34.921793 - - VK_KHR_external_semaphore_capabilities, version 1
Wed Sep 08 2021 22:01:34.921801 - - VK_KHR_get_display_properties2, version 1
Wed Sep 08 2021 22:01:34.921809 - - VK_KHR_get_physical_device_properties2, version 2
Wed Sep 08 2021 22:01:34.921817 - - VK_KHR_get_surface_capabilities2, version 1
Wed Sep 08 2021 22:01:34.921826 - - VK_KHR_surface, version 25
Wed Sep 08 2021 22:01:34.921833 - - VK_KHR_surface_protected_capabilities, version 1
Wed Sep 08 2021 22:01:34.921841 - - VK_KHR_wayland_surface, version 6
Wed Sep 08 2021 22:01:34.921849 - - VK_KHR_xcb_surface, version 6
Wed Sep 08 2021 22:01:34.921856 - - VK_KHR_xlib_surface, version 6
Wed Sep 08 2021 22:01:34.921864 - - VK_EXT_acquire_xlib_display, version 1
Wed Sep 08 2021 22:01:34.921872 - - VK_EXT_debug_report, version 9
Wed Sep 08 2021 22:01:34.921881 - - VK_EXT_direct_mode_display, version 1
Wed Sep 08 2021 22:01:34.921893 - - VK_EXT_display_surface_counter, version 1
Wed Sep 08 2021 22:01:34.921900 - - VK_EXT_debug_utils, version 2
Wed Sep 08 2021 22:01:34.921909 - Direct mode features: present
Wed Sep 08 2021 22:01:34.921917 - Requesting 9 instance extensions:
Wed Sep 08 2021 22:01:34.921924 - - VK_KHR_surface
Wed Sep 08 2021 22:01:34.921930 - - VK_KHR_xcb_surface
Wed Sep 08 2021 22:01:34.921938 - - VK_KHR_display
Wed Sep 08 2021 22:01:34.921945 - - VK_EXT_direct_mode_display
Wed Sep 08 2021 22:01:34.921952 - - VK_EXT_acquire_xlib_display
Wed Sep 08 2021 22:01:34.921959 - - VK_EXT_display_surface_counter
Wed Sep 08 2021 22:01:34.921967 - - VK_KHR_external_memory_capabilities
Wed Sep 08 2021 22:01:34.921974 - - VK_KHR_external_semaphore_capabilities
Wed Sep 08 2021 22:01:34.921981 - - VK_KHR_get_physical_device_properties2
Wed Sep 08 2021 22:01:34.925571 - HMD deviceUUID is 0
Wed Sep 08 2021 22:01:34.925586 - Looking for direct display through RandR
Wed Sep 08 2021 22:01:34.925595 - - Root 0x1e8
Wed Sep 08 2021 22:01:35.015692 - - Output 0x1bd - 30 modes, 1 preferred
Wed Sep 08 2021 22:01:35.015706 - - Mode 0 0x1be 1920x1080 (looking for 2880x1600)
Wed Sep 08 2021 22:01:35.017443 - - Output 0x1dc - 18 modes, 1 preferred
Wed Sep 08 2021 22:01:35.017450 - - Mode 0 0x1be 1920x1080 (looking for 2880x1600)
Wed Sep 08 2021 22:01:35.017467 - - Output 0x1de - 0 modes, 0 preferred
Wed Sep 08 2021 22:01:35.017483 - - Output 0x1df - 0 modes, 0 preferred
Wed Sep 08 2021 22:01:35.017499 - - Output 0x1e0 - 0 modes, 0 preferred
Wed Sep 08 2021 22:01:35.017513 - - Output 0x1e1 - 0 modes, 0 preferred
Wed Sep 08 2021 22:01:35.017526 - - Output 0x1e2 - 0 modes, 0 preferred
Wed Sep 08 2021 22:01:35.017539 - - Output 0x1e3 - 0 modes, 0 preferred
Wed Sep 08 2021 22:01:35.017547 - Tried to find direct display through RandR: (nil)
Wed Sep 08 2021 22:01:35.017553 - Looking for direct display through Vulkan WSI
vrclient_vrstartup.txt.txt
Wed Sep 08 2021 17:49:00.480425 - Unable to connect to pipe errno=111
Wed Sep 08 2021 17:49:00.480449 - Starting vrserver process: /home/user/.local/share/Steam/steamapps/common/SteamVR/bin/linux64/vrserver
Wed Sep 08 2021 17:49:00.630783 - CIPCPipe::ConnectPipe(SteamVR_Namespace) attempting connect to steamvr:SteamVR_Namespace
Wed Sep 08 2021 17:49:00.630844 - CSharedResourceNamespaceClient::Init(): received namespace data 4722
Wed Sep 08 2021 17:49:00.630863 - CIPCPipe::ConnectPipe(VR_ServerPipe_4722) attempting connect to steamvr:VR_ServerPipe_4722
Wed Sep 08 2021 17:49:01.403778 - Received success response from vrserver connect
Wed Sep 08 2021 17:49:03.505555 - Timed out waiting for a good app key
Wed Sep 08 2021 17:49:03.505575 - App key after connect message:steam.overlay.250820
Wed Sep 08 2021 17:49:03.507522 - CIPCPipe::ConnectPipe(VR_CompositorPipe_4722) attempting connect to steamvr:VR_CompositorPipe_4722
Wed Sep 08 2021 17:49:03.507534 - Unable to connect to pipe errno=111
Wed Sep 08 2021 17:49:03.512009 - Starting vrcompositor process: /home/user/.local/share/Steam/steamapps/common/SteamVR/bin/linux64/vrcompositor-launcher
Wed Sep 08 2021 17:49:03.516937 - CIPCPipe::ConnectPipe(VR_CompositorPipe_4722) attempting connect to steamvr:VR_CompositorPipe_4722
Wed Sep 08 2021 17:49:03.516954 - Unable to connect to pipe errno=111
Wed Sep 08 2021 17:49:03.617036 - CIPCPipe::ConnectPipe(VR_CompositorPipe_4722) attempting connect to steamvr:VR_CompositorPipe_4722
Wed Sep 08 2021 17:49:03.905175 - Error reading from socket
Wed Sep 08 2021 17:49:03.905209 - Unable to read message from socket: 104
Wed Sep 08 2021 17:49:03.905227 - GetNextMessage failed while waiting for message of type 501 on pipe VR_CompositorPipe_4722
Wed Sep 08 2021 17:49:03.905235 - Invalid response to connect message. Connect failed
Wed Sep 08 2021 17:49:03.910060 - Started /home/user/.local/share/Steam/steamapps/common/SteamVR/bin/linux64/vrmonitor with pid 4802
Wed Sep 08 2021 22:01:28.785110 - //==============================================================================================
Wed Sep 08 2021 22:01:28.785185 - ================================================================================================
Wed Sep 08 2021 22:01:28.785194 - ================================================================================================
Wed Sep 08 2021 22:01:28.785201 - Set thread 0x7eff63404640 priority to: -15
Wed Sep 08 2021 22:01:28.785341 - vrstartup 1.19.7 startup with PID=46777, config=/home/user/.local/share/Steam/config, runtime=/home/user/.local/share/Steam/steamapps/common/SteamVR
Wed Sep 08 2021 22:01:28.785367 - vrclient type=VRApplication_Bootstrapper
Wed Sep 08 2021 22:01:28.785710 - [Settings] Load Default Json Settings from /home/user/.local/share/Steam/steamapps/common/SteamVR/drivers/htc/resources/settings/default.vrsettings
Wed Sep 08 2021 22:01:28.785736 - [Settings] Load Default Json Settings from /home/user/.local/share/Steam/steamapps/common/SteamVR/drivers/lighthouse/resources/settings/default.vrsettings
Wed Sep 08 2021 22:01:28.785758 - [Settings] Load Default Json Settings from /home/user/.local/share/Steam/steamapps/common/SteamVR/drivers/null/resources/settings/default.vrsettings
Wed Sep 08 2021 22:01:28.785844 - [Settings] Load Default Json Settings from /home/user/.local/share/Steam/steamapps/common/SteamVR/resources/settings/default.vrsettings
Wed Sep 08 2021 22:01:28.786025 - [Settings] Load Json Settings from /home/user/.local/share/Steam/config/steamvr.vrsettings
Wed Sep 08 2021 22:01:28.809649 - CIPCPipe::ConnectPipe(SteamVR_Namespace) attempting connect to steamvr:SteamVR_Namespace
Wed Sep 08 2021 22:01:28.809669 - Unable to connect to pipe errno=111
Wed Sep 08 2021 22:01:28.809704 - Starting vrserver process: /home/user/.local/share/Steam/steamapps/common/SteamVR/bin/linux64/vrserver
Wed Sep 08 2021 22:01:28.960559 - CIPCPipe::ConnectPipe(SteamVR_Namespace) attempting connect to steamvr:SteamVR_Namespace
Wed Sep 08 2021 22:01:28.960616 - CSharedResourceNamespaceClient::Init(): received namespace data 47138
Wed Sep 08 2021 22:01:28.960636 - CIPCPipe::ConnectPipe(VR_ServerPipe_47138) attempting connect to steamvr:VR_ServerPipe_47138
Wed Sep 08 2021 22:01:29.746698 - Received success response from vrserver connect
Wed Sep 08 2021 22:01:31.849891 - Timed out waiting for a good app key
Wed Sep 08 2021 22:01:31.849933 - App key after connect message:steam.overlay.250820
Wed Sep 08 2021 22:01:31.853189 - CIPCPipe::ConnectPipe(VR_CompositorPipe_47138) attempting connect to steamvr:VR_CompositorPipe_47138
Wed Sep 08 2021 22:01:31.853200 - Unable to connect to pipe errno=111
Wed Sep 08 2021 22:01:31.858494 - Starting vrcompositor process: /home/user/.local/share/Steam/steamapps/common/SteamVR/bin/linux64/vrcompositor-launcher
Wed Sep 08 2021 22:01:31.863763 - CIPCPipe::ConnectPipe(VR_CompositorPipe_47138) attempting connect to steamvr:VR_CompositorPipe_47138
Wed Sep 08 2021 22:01:31.863792 - Unable to connect to pipe errno=111
Wed Sep 08 2021 22:01:31.963886 - CIPCPipe::ConnectPipe(VR_CompositorPipe_47138) attempting connect to steamvr:VR_CompositorPipe_47138
Wed Sep 08 2021 22:01:32.313642 - Error reading from socket
Wed Sep 08 2021 22:01:32.313677 - Unable to read message from socket: 104
Wed Sep 08 2021 22:01:32.313703 - GetNextMessage failed while waiting for message of type 501 on pipe VR_CompositorPipe_47138
Wed Sep 08 2021 22:01:32.313716 - Invalid response to connect message. Connect failed
Wed Sep 08 2021 22:01:32.319444 - Started /home/user/.local/share/Steam/steamapps/common/SteamVR/bin/linux64/vrmonitor with pid 47313
