Hello,
I’m trying to use the mpv from the unstable channel (because it has a patch related to this issue),
but I can’t compile this example and gives me this error:
└─> gcc -o simple simple.c `pkg-config --libs --cflags mpv`
/nix/store/lz1bwpdvlywij5ir0fmncgqa83dlpwhn-binutils-2.39/bin/ld: /nix/store/qr4br1dgaiwxjr75xk8hh6p1avi5xyq8-openal-soft-1.22.2/lib/libopenal.so.1: undefined reference to `std::condition_variable::wait(std::unique_lock<std::mutex>&)@GLIBCXX_3.4.30'
collect2: error: ld returned 1 exit status
when I add mpv from the unstable channel in my shell.nix
file:
system = "x64_86-linux";
unstable = import <nixos-unstable> { allowUnfree = true; };
{ pkgs ? import <nixpkgs> { allowUnfree = true; } }:
pkgs.mkShell rec {
buildInputs = with pkgs; [
unstable.mpv
pkg-config
I also tried using mpv-unwrapped.dev
, but didn’t work.
you can ask me for more context if needed
