Hi everyone,
I am trying to make a simple derivation working but getting permission denied error. I believe this is a recommended way to do so and I have done the same for plenty of the other npm packages and it worked. However, the same approach doesn’t work for this particular npm package: char-regex-1.0.2. Please refer to the below.
{ nixpkgs }:
with nixpkgs;
charRegex = stdenv.mkDerivation rec {
pname = "char-regex";
version = "1.0.2";
src = fetchurl {
url = "https://registry.yarnpkg.com/${pname}/-/${pname}-${version}.tgz";
sha1 = "d744358226217f981ed58f479b1d6bcc29545dcf";
installPhase = ''
runHook preInstall
mkdir -p "$out/lib/node_modules/${pname}"
cp -r . "$out/lib/node_modules/${pname}"
runHook postInstall
in stdenv.mkDerivation {
name = "example-env";
buildInputs = [ nodejs ];
NODE_PATH = "${charRegex}/lib/node_modules";
And then getting an error:
$ nix-shell --pure ./example.nix
/nix/store/1hyfs1z08lwircjsd8lzlf9rfak0zy3m-char-regex-1.0.2.drv
building '/nix/store/1hyfs1z08lwircjsd8lzlf9rfak0zy3m-char-regex-1.0.2.drv'...
unpacking sources
unpacking source archive /nix/store/v9p98kqplf4kflmy91p0687xlvr6klb1-char-regex-1.0.2.tgz
source root is package
chmod: cannot access 'package/LICENSE': Permission denied
chmod: cannot access 'package/index.js': Permission denied
chmod: cannot access 'package/README.md': Permission denied
chmod: cannot access 'package/package.json': Permission denied
chmod: cannot access 'package/index.d.ts': Permission denied
builder for '/nix/store/1hyfs1z08lwircjsd8lzlf9rfak0zy3m-char-regex-1.0.2.drv' failed with exit code 1
error: build of '/nix/store/1hyfs1z08lwircjsd8lzlf9rfak0zy3m-char-regex-1.0.2.drv' failed
Can you please help to understand the issue and work out a way to fix that?
Cheers,
Oleg
You can’t write to the nix store.
charRegex is a separate derivation, so when you go to run your other package build, the charRegex will be read-only. This is why you are getting permission issues, node is trying to change the permissions of something in the nix store. To solve this, you should probably copy charRegex into a write-able directory, then point NODE_PATH to it.
Yeah, I know that the nix store is read-only when you have a derivation built and operational. The error is happening during the derivation build cycle. In particular, nix tries to unpack the source and throwing an error, I think, during unpackPhase execution.
So I am wondering if there is a hook/hack to make this kind of thing work? Like, override unpackPhase with sudo or something. Any suggestions are appreciated.
Please note, I have built a number of npm modules in exactly the same way and they seem to be working fine but not the charRegex
I apologize, you’re correct. GitHub - Richienb/char-regex: A regex to match any full character, considering weird character ranges. did not cut a release correctly, as the unpacked directory doesn’t have execute permission, so you can’t inspect it.
$ nix-shell tmp.nix
/nix/store/k9g0cavgrxz1c8x7nzm3zkrcmwm5qcfv-char-regex-1.0.2.tgz.drv
building '/nix/store/k9g0cavgrxz1c8x7nzm3zkrcmwm5qcfv-char-regex-1.0.2.tgz.drv'...
trying https://registry.yarnpkg.com/char-regex/-/char-regex-1.0.2.tgz
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 2476 100 2476 0 0 8065 0 --:--:-- --:--:-- --:--:-- 8065
[nix-shell:/home/jon/projects/nixpkgs]$ unpackPhase
find: ‘package/README.md’: Permission denied
find: ‘package/index.js’: Permission denied
find: ‘package/LICENSE’: Permission denied
find: ‘package/index.d.ts’: Permission denied
find: ‘package/package.json’: Permission denied
[nix-shell:/home/jon/projects/nixpkgs]$ mkdir tmp
[nix-shell:/home/jon/projects/nixpkgs]$ cd tmp/
[nix-shell:/home/jon/projects/nixpkgs/tmp]$ tar xf /nix/store/v9p98kqplf4kflmy91p0687xlvr6klb1-char-regex-1.0.2.tgz
[nix-shell:/home/jon/projects/nixpkgs/tmp]$ ls
package
[nix-shell:/home/jon/projects/nixpkgs/tmp]$ cd package/
bash: cd: package/: Permission denied
[nix-shell:/home/jon/projects/nixpkgs/tmp]$ ls -l
drw-r--r-- - jon 18 Feb 2020 package
[nix-shell:/home/jon/projects/nixpkgs/tmp]$ chmod +x package/
package
index.d.ts index.js LICENSE package.json README.md
Yeah, the package directory lacks the execution permission bit in the archive:
$ lesspipe /nix/store/v9p98kqplf4kflmy91p0687xlvr6klb1-char-regex-1.0.2.tgz
drw-rw-rw- 0/0 0 2020-02-18 10:50 package
-rw-rw-rw- 0/0 297 2020-02-18 10:50 package/index.d.ts
-rw-rw-rw- 0/0 1920 2020-02-18 10:50 package/index.js
-rw-rw-rw- 0/0 1092 2020-01-31 11:31 package/LICENSE
-rw-rw-rw- 0/0 937 2020-02-18 10:51 package/package.json
-rw-rw-rw- 0/0 713 2020-02-18 10:50 package/README.md
For now, you can work around it using
dontMakeSourcesWritable = true;
postUnpack = ''
chmod +x package
