Edit: This could probably use input from someone with more perspective on how the Python packaging update has and may continue to shake out. The changes in my first post got it to build, but ran into Python pkg_resources import errors while running tests this morning. Getting it running makes me suspect this is a moving target, and that there’s a good chance my changes are incomplete or miss the forest for the trees.
Today I updated my unstable channel for the first time in a bit to get a newer chromedriver and found that a requirements.nix expression I use (generated by pypi2nix 1.8.1, and significantly hand-edited) was no longer working.
It took me a bit to track down changes and fiddle/debug until this worked, so I figured I’d share in case it gets indexed and saves someone else the same work…
I got an error like:
error: attribute ‘patchPhase’ missing, at /Users/abathur/…/requirements.nix :25:24
Which I fixed by following what pypi2nix did in https://github.com/nix-community/pypi2nix/pull/323, which amounts to something like:
--- oldrequirements.nix 2019-10-23 22:19:11.837634932 -0500
+++ requirements.nix 2019-10-23 22:18:17.201316313 -0500
@@ -18,15 +18,6 @@
inherit pkgs;
inherit (pkgs) stdenv;
python = pkgs.python36;
- # patching pip so it does not try to remove files when running nix-shell
- overrides =
- self: super: {
- bootstrapped-pip = super.bootstrapped-pip.overrideDerivation (old: {
- patchPhase = old.patchPhase + ''
- sed -i -e "s|paths_to_remove.remove(auto_confirm)|#paths_to_remove.remove(auto_confirm)|" -e "s|self.uninstalled = paths_to_remove|#self.uninstalled = paths_to_remove|" $out/${pkgs.python36.sitePackages}/pip/req/req_install.py
and subsequently found I needed to track the changes in https://github.com/nix-community/pypi2nix/pull/273, like:
__old = pythonPackages;
inherit interpreter;
- mkDerivation = pythonPackages.buildPythonPackage;
+ mkDerivation = args: pythonPackages.buildPythonPackage (args // {
+ nativeBuildInputs = (args.nativeBuildInputs or []) ++ args.buildInputs;
packages = pkgs;
overrideDerivation = drv: f:
pythonPackages.buildPythonPackage (drv.drvAttrs // f drv.drvAttrs // { meta = drv.meta; });
@@ -217,7 +210,7 @@
By this point I assumed I’d need to track most upstream pypi2nix changes to its own requirements.nix file, but adopting the changes in https://github.com/nix-community/pypi2nix/pull/346 caused trouble with multiple active setuptools versions which manifested like:
pythonCatchConflictsPhase
Processing ./setuptools-41.4.0-py2.py3-none-any.whl
Installing collected packages: setuptools
Found existing installation: setuptools 41.2.0
Uninstalling setuptools-41.2.0:
ERROR: Could not install packages due to an EnvironmentError: [Errno 13] Permission denied: '/nix/store/pqz2jb2y8sfz7m0xb4kgw705im1in86a-python3.6-setuptools-41.2.0/lib/python3.6/site-packages/setuptools-41.2.0-py3.6.egg'
Consider using the `--user` option or check the permissions.
I won’t show a diff for these changes, since they depend a lot on what packages are in your requirements.nix. I wonder if this just comes down to the lag between nixpkgs master and unstable, but in any case my short-run fix (which is working for now…) is to just comment out the derivation for setuptools 41.4.0, and all of the self."setuptools"
buildInputs references to it.
I also had to make some smaller changes for specific dependencies:
- add
pythonPackages.setuptools
as a propagatedBuildInput to the derivation for a private package that uses pkg_resources at runtime. - fix additional dependency-conflict failure for a package that needs the
--no-deps
flag passed topip install
, which required a simple update (for a change in https://github.com/NixOS/nixpkgs/pull/64997):
- installFlags = ["--no-deps"];
+ pipInstallFlags = ["--no-deps"];
HTH
