Hi all,
with the 19.09 i use synergy software to Share one mouse and keyboard between multiple computers
after the 20.03 upgrade , synergy no longer works.
I have a idea about change with ssh X11 forwarding but how verify ?
Pierre
Hi all,
Pierre
Hi, I had the same problem after upgrading.
networking.firewall.allowedTCPPorts = [ 24800 ];
).Cheers,
Rodney
Hi Rodney,
i use Ip adress
My Nixos installation is client.
so , i use synergyc …
Cheers.
Pierre
I try to have log on client side … not found …
I verified the server configuration and i found in the log , the solution
during the upgrade , I changed my hostname on client desktop.
2020-04-27T11:12:29] NOTE: accepted client connection
[2020-04-27T11:12:29] NOTE: disconnecting client “nixos-2003”
[2020-04-27T11:12:29] WARNING: unrecognised client name “nixos-2003”, check server config
[2020-04-27T11:12:29] NOTE: client “nixos-2003” has disconnected
OK good that would do it.
If you are using the services.synergy.client
NixOS module, you can see the logs with
systemctl --user status synergy-client.service
or
journalctl --user -u synergy-client.service -e
Hello,
Thanks for your idea.
Pierre
