Hello, guys , I am using a USB network adapter. I have added this information. Is this a normal phenomenon at present?
This is the information for the USB network card, Based on online information, this USB board already exists in the kernel, and I am using the default kernel 26.05.
Bus 004 Device 002: ID 0e8d:7612 MediaTek Inc. MT7612U 802.11a/b/g/n/ac Wireless Adapter
hardware.usb-modeswitch.enable = true
usb-modeswitch-data
However, this doesnāt work; you still need to manually switch each time.
[nix-shell:~]$ sudo usb_modeswitch -KW -v 0e8d -p 2870
Take all parameters from the command line
* usb_modeswitch: handle USB devices with multiple modes
* Version 2.6.2 (C) Josua Dietze 2017
* Based on libusb1/libusbx
! PLEASE REPORT NEW CONFIGURATIONS !
DefaultVendor= 0x0e8d
DefaultProduct= 0x2870
StandardEject=1
Look for default devices ...
found USB ID 1d6b:0003
found USB ID 04f3:0c7e
found USB ID 0e8d:2870
vendor ID matched
product ID matched
found USB ID 8087:0033
found USB ID 04f2:b73b
found USB ID 1d6b:0002
Found devices in default mode (1)
Access device 005 on bus 003
Get the current device configuration ...
Current configuration number is 1
Use interface number 0
with class 8
Use endpoints 0x02 (out) and 0x82 (in)
USB description data (for identification)
Manufacturer: ?
Product: ?
Serial No.: ?
Sending standard EJECT sequence
Looking for active drivers ...
OK, driver detached
Set up interface 0
Use endpoint 0x02 for message sending ...
Trying to send message 1 to endpoint 0x02 ...
OK, message successfully sent
Read the response to message 1 (CSW) ...
Response successfully read (0 bytes), status 0
Trying to send message 2 to endpoint 0x02 ...
Read the response to message 2 (CSW) ...
Response successfully read (13 bytes), status 0
Trying to send message 3 to endpoint 0x02 ...
Device seems to have vanished right after sending. Good.
Device is gone, skip any further commands
-> Run lsusb to note any changes. Bye!
[nix-shell:~]$ lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 002: ID 04f2:b73b Chicony Electronics Co., Ltd HP HD Camera
Bus 003 Device 003: ID 04f3:0c7e Elan Microelectronics Corp. ELAN:ARM-M4
Bus 003 Device 004: ID 8087:0033 Intel Corp. AX211 Bluetooth
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
