I’m writing a flake which uses nosys to abstract treatment of systems.
nosys
‘de-systemizes’ the nixpkgs
input when passing it to the flake’s outputs; quoting the nosys
README
Before desystemizing:
nixpkgs, # <---- This `nixpkgs` still has the `system` e.g. legacyPackages.${system}.zlib
After desystemizing:
nixpkgs, # <---- This `nixpkgs` has systems removed e.g. legacyPackages.zlib
This allows nixpkgs
to be used without worrying about the system (pkgs.whatever
in the following sample):
inherit (nixpkgs.legacyPackages) pkgs;
devShell = pkgs.mkShell {
packages = [ pkgs.whatever ];
However, something is not quite right in my attempts to use a package from a flake input other than nixpkgs
packages = [ pkgs.whatever other_flake_input.packages.default ];
works, but
packages = [ pkgs.whatever other_flake_input.packages.xxx ];
errors with attribute 'xxx' missing
, even though in the outputs of other_flake_input
(which is also defined using nosys
packages.default = self.packages.xxx
What might I be doing wrong?
