Using a nix flake in a flake (e.g. buildInputs)
Hi, I somehow cannot figure how to use / access a dependency in a flake.
Consider a simple hello world flake, defined as, and available at https://github.com/sbellem/hello-flake:
    nixpkgs.url = "github:nixos/nixpkgs";
      let pkgs = nixpkgs.legacyPackages.${system};
        packages.hello = pkgs.hello;
        defaultPackage = pkgs.hello;
        devShell = pkgs.mkShell { buildInputs = [ pkgs.hello pkgs.cowsay ]; };
Now, invoking the hello program with nix shell or nix develop as in the following works.
nix develop github:sbellem/hello-flake -c hello
But trying to use it in a flake such as the following does not work …
  description = "hello hello world";
  inputs.nixpkgs.url = "github:NixOS/nixpkgs";
  inputs.hello-flake.url = "github:sbellem/hello-flake";
  outputs = { self, nixpkgs, flake-utils, hello-flake }:
          buildInputs = [
            hello-flake
What am I doing wrong?
Does this work?
          buildInputs = [
            hello-flake.defaultPackage.x86_64-linux
Flakes are really picking up, we get this question in slightly different forms almost every day now - also probably means we need better documentation for this exact thing, or work out the ergonomics a bit better :slight_smile:
@mackenzie suggestion should work, and you can even do this with flake-utils:
          buildInputs = [
            hello-flake.defaultPackage.${system}
The cleaner approach that doesn’t rely on your config being entirely in flake.nix is using module._args or an overlay, see this related thread: Install agenix in "environment.systemPackages" on nixos with flakes
For devshells overlays are definitely more ergonomic.
Thanks! Yes that works!
Thanks! That’s helpful! Yeah, flakes are cool!
I added some notes on the toy project: https://github.com/sbellem/hello-flake.
I tried adding an overlay, but struggling with
error: All overlays passed to nixpkgs must be functions
I somehow thought that for instance, this would work:
        # to use as an overlay
        overlay = final: prev: {
          boost = prev.boost.override {
            python = final.python3;
          rr = prev.callPackage ./pkgs/rr {
            stdenv = final.stdenv_32bit;
I’ve looked at the agenix code, and followed their structure, but still got the same error. If you have any pointers to other examples, or documentation on writing an overlay for a flake, that would be great.
Overlays are not bound by system, you need to move it out of the eachDefaultSystem call:
(flake-utils.lib.eachDefaultSystem (system:
Ah, great! That works! Thanks!
