Using a "raw" `gcc` inside `buildFHSUserEnv`
I would like to have a buildFHSUserEnv-shell in which I can use a “raw” gcc that picks up libraries from system-locations like /usr/lib etc. to build things.
So far I have this shell.nix:
{ pkgs ? import <nixpkgs> { } }:
(pkgs.buildFHSUserEnv.override { stdenv = pkgs.stdenvNoCC; } {
  name = "fhs";
  targetPkgs = pkgs: (with pkgs; [
    gcc-unwrapped
    binutils-unwrapped
  multiPkgs = null;
}).env
Entering this shell gives me:
these 6 derivations will be built:
  /nix/store/8jl4fgm5mrv3xgrdy75lzfgclhsnvfy9-profile.drv
  /nix/store/1l7qh9p856b3pibrgvnk59ys9i2n1sqx-fhs-chrootenv-etc.drv
  /nix/store/7zw4ijckcacgij9jqfa9wjinh7qa7b7v-builder.pl.drv
  /nix/store/vlklkhis1p4wd4l9r8r8ydcxdfp4b345-fhs-usr-target.drv
  /nix/store/q9z97giwiiz4agxd6jqqm7kzrsinkf0l-fhs-fhs.drv
  /nix/store/pqw56xqy7xyyqni1a9cqslsibsyr7qv5-fhs-init.drv
these 4 paths will be fetched (0.08 MiB download, 0.37 MiB unpacked):
  /nix/store/4y965wrv3shgg2s1ca431qpbrsb4dbag-stdenv-linux
  /nix/store/a9g7p6fwanw66j5djzila7ql1hky759z-bash-interactive-4.4-p23-dev
  /nix/store/j5cv3kba4cwx4dcnmsmhb25lfla0snzq-chrootenv
  /nix/store/wgap303sj9zqz63gw7nqxvf4dqz2hgai-stdenv-linux
copying path '/nix/store/j5cv3kba4cwx4dcnmsmhb25lfla0snzq-chrootenv' from 'https://cache.nixos.org'...
copying path '/nix/store/a9g7p6fwanw66j5djzila7ql1hky759z-bash-interactive-4.4-p23-dev' from 'https://cache.nixos.org'...
copying path '/nix/store/4y965wrv3shgg2s1ca431qpbrsb4dbag-stdenv-linux' from 'https://cache.nixos.org'...
copying path '/nix/store/wgap303sj9zqz63gw7nqxvf4dqz2hgai-stdenv-linux' from 'https://cache.nixos.org'...
building '/nix/store/7zw4ijckcacgij9jqfa9wjinh7qa7b7v-builder.pl.drv'...
building '/nix/store/8jl4fgm5mrv3xgrdy75lzfgclhsnvfy9-profile.drv'...
building '/nix/store/1l7qh9p856b3pibrgvnk59ys9i2n1sqx-fhs-chrootenv-etc.drv'...
building '/nix/store/vlklkhis1p4wd4l9r8r8ydcxdfp4b345-fhs-usr-target.drv'...
collision between `/nix/store/0c7c96gikmzv87i7lv3vq5s1cmfjd6zf-glibc-2.31-74/lib/locale/locale-archive' and `/nix/store/20dyxqvd9rnwzdnpdzb8vnv8w3vwa8wx-glibc-locales-2.31-74/lib/locale/locale-archive'
collision between `/nix/store/c10296m7xgm3ksibcklb2xf48jr635x3-gcc-9.3.0-lib/lib/libgcc_s.so' and `/nix/store/0c7c96gikmzv87i7lv3vq5s1cmfjd6zf-glibc-2.31-74/lib/libgcc_s.so'
collision between `/nix/store/c10296m7xgm3ksibcklb2xf48jr635x3-gcc-9.3.0-lib/lib/libgcc_s.so.1' and `/nix/store/0c7c96gikmzv87i7lv3vq5s1cmfjd6zf-glibc-2.31-74/lib/libgcc_s.so.1'
collision between `/nix/store/c10296m7xgm3ksibcklb2xf48jr635x3-gcc-9.3.0-lib/lib64/libgcc_s.so' and `/nix/store/0c7c96gikmzv87i7lv3vq5s1cmfjd6zf-glibc-2.31-74/lib64/libgcc_s.so'
collision between `/nix/store/c10296m7xgm3ksibcklb2xf48jr635x3-gcc-9.3.0-lib/lib64/libgcc_s.so.1' and `/nix/store/0c7c96gikmzv87i7lv3vq5s1cmfjd6zf-glibc-2.31-74/lib64/libgcc_s.so.1'
Use of uninitialized value in string eq at /nix/store/w3awmn2x43g2yymp7yzb3985r3b89f3i-builder.pl line 133.
collision between `/nix/store/jki00pcw0npk9hfmxc5ln41003225b1h-shadow-4.8.1/etc/pam.d' and `/nix/store/m267yyzj9y73827wh3wjgy02nv2b9pxz-fhs-chrootenv-etc/etc/pam.d'
collision between `/nix/store/jki00pcw0npk9hfmxc5ln41003225b1h-shadow-4.8.1/etc/login.defs' and `/nix/store/m267yyzj9y73827wh3wjgy02nv2b9pxz-fhs-chrootenv-etc/etc/login.defs'
created 1332 symlinks in user environment
building '/nix/store/q9z97giwiiz4agxd6jqqm7kzrsinkf0l-fhs-fhs.drv'...
building '/nix/store/pqw56xqy7xyyqni1a9cqslsibsyr7qv5-fhs-init.drv'...
So there are at least some collisions because I think buildFHSUserEnv pulls in glibc by itself.
But the actual problem is that this gcc/ld doesn’t work:
$ gcc test.c
/usr/bin/ld: cannot find crt1.o: No such file or directory
/usr/bin/ld: cannot find crti.o: No such file or directory
/usr/bin/ld: cannot find -lgcc_s
/usr/bin/ld: cannot find -lc
/usr/bin/ld: cannot find crtn.o: No such file
(test.c is a simple “Hello, World!”)
But all of these, i.e., crt1.o, crti.o, libgcc_s.so, libc.so and crtn.o do exist in /usr/lib inside the FHS-env.
Output of gcc -print-search-dirs:
$ gcc -print-search-dirs
install: /nix/store/fvf3qjqa5qpcjjkq37pb6ypnk1mzhf5h-gcc-9.3.0/lib/gcc/x86_64-unknown-linux-gnu/9.3.0/
programs: =/nix/store/fvf3qjqa5qpcjjkq37pb6ypnk1mzhf5h-gcc-9.3.0/libexec/gcc/x86_64-unknown-linux-gnu/9.3.0/:/nix/store/fvf3qjqa5qpcjjkq37pb6ypnk1mzhf5h-gcc-9.3.0/libexec/gcc/x86_64-unknown-linux-gnu/9.3.0/:/nix/store/fvf3qjqa5qpcjjkq37pb6ypnk1mzhf5h-gcc-9.3.0/libexec/gcc/x86_64-unknown-linux-gnu/:/nix/store/fvf3qjqa5qpcjjkq37pb6ypnk1mzhf5h-gcc-9.3.0/lib/gcc/x86_64-unknown-linux-gnu/9.3.0/:/nix/store/fvf3qjqa5qpcjjkq37pb6ypnk1mzhf5h-gcc-9.3.0/lib/gcc/x86_64-unknown-linux-gnu/:/nix/store/fvf3qjqa5qpcjjkq37pb6ypnk1mzhf5h-gcc-9.3.0/lib/gcc/x86_64-unknown-linux-gnu/9.3.0/../../../../x86_64-unknown-linux-gnu/bin/x86_64-unknown-linux-gnu/9.3.0/:/nix/store/fvf3qjqa5qpcjjkq37pb6ypnk1mzhf5h-gcc-9.3.0/lib/gcc/x86_64-unknown-linux-gnu/9.3.0/../../../../x86_64-unknown-linux-gnu/bin/
libraries: =/nix/store/fvf3qjqa5qpcjjkq37pb6ypnk1mzhf5h-gcc-9.3.0/lib/gcc/x86_64-unknown-linux-gnu/9.3.0/:/nix/store/fvf3qjqa5qpcjjkq37pb6ypnk1mzhf5h-gcc-9.3.0/lib/gcc/x86_64-unknown-linux-gnu/9.3.0/../../../../x86_64-unknown-linux-gnu/lib/x86_64-unknown-linux-gnu/9.3.0/:/nix/store/fvf3qjqa5qpcjjkq37pb6ypnk1mzhf5h-gcc-9.3.0/lib/gcc/x86_64-unknown-linux-gnu/9.3.0/../../../../x86_64-unknown-linux-gnu/lib/../lib64/:/nix/store/fvf3qjqa5qpcjjkq37pb6ypnk1mzhf5h-gcc-9.3.0/lib/gcc/x86_64-unknown-linux-gnu/9.3.0/../../../x86_64-unknown-linux-gnu/9.3.0/:/nix/store/fvf3qjqa5qpcjjkq37pb6ypnk1mzhf5h-gcc-9.3.0/lib/gcc/x86_64-unknown-linux-gnu/9.3.0/../../../../lib64/:/nix/store/fvf3qjqa5qpcjjkq37pb6ypnk1mzhf5h-gcc-9.3.0/lib/gcc/x86_64-unknown-linux-gnu/9.3.0/../../../../x86_64-unknown-linux-gnu/lib/:/nix/store/fvf3qjqa5qpcjjkq37pb6ypnk1mzhf5h-gcc-9.3.0/lib/gcc/x86_64-unknown-linux-gnu/9.3.0/../../../
So these actually still point into /nix/store, and locations like /usr/lib don’t seem to be part of it?
Thanks!
Edit: Okay, the following actually kind of works, but I don’t really like it:
  runScript = ''
    env LIBRARY_PATH=/usr/lib C_INCLUDE_PATH=/usr/include CPLUS_INCLUDE_PATH=/usr/include CMAKE_LIBRARY_PATH=/usr/lib CMAKE_INCLUDE_PATH=/usr/include bash
I’d like it if “normal” paths would be searched by default, and I wouldn’t need to specify this again for individual build-tools etc. What’s the magic that makes this work in “other” distros, and where does nix remove this magic?
Another option would be to use the wrapped compilers, and just use NIX_CFLAGS_COMPILE and NIX_LDFLAGS to reference the fhs paths. Then you can mix nix and other packages.
