That makes sense and I think I’m getting closer. When changed home.packages to use micronaut-1_3_3 I am now getting an error from the overlay.
# nixos-rebuild switch
building Nix...
error: attribute 'micronaut-1_3_3' missing, at /nix/store/n4cy1al11ncn3hn4fp2maw5zhldsvvvi-source/overlays/use-adoptopenjdk11/default.nix:2:23
How do I get the overlay to recognize the package?
building Nix...
error: anonymous function at /nix/store/g85jk50f1qwk97rs6pwdf3k65ks3ridj-nur/nur/default.nix:1:1 called with unexpected argument 'overlays', at /etc/nixos/user.nix:15:11
What I was originally trying to do is use the nixpkgs.overlays option for home manager with the overlay.
I just wanted to follow up that I found the solution.
My problem was that I thought overlays could be applied to the nur repo. This is definitely not the case. Instead, the packages need to be added to nixpkgs first. The nur namespace cannot be used. This can be done using the overlay provided by the nur template.
I think it would be nice to add overlays to the nur repo. Then overlays could be applied and the nur namespace can be used. The overlays can be isolated to just that repo. The idea of use-adoptopenjdk11 is to only change the jdk for the packages in the nur repo.
If use-adoptopenjdk11 can be written to detect all packages with jdk and override it automatically that would be much nicer.
