I am new to NixOS, just installed yesterday. I have a fully dashboard-managed cloudflared tunnel ready to go with all the rules and public hostnames already setup and everything that i used to use with my old archlinux setup.
Long story short, after a painstaking search through the entirety of google, github and nixos discourse, i have come to find that there is not much there for using cloudflared dashboard-managed existing tunnels.
I currently do not use home-manager OR flakes. I have the following service config for cloudflared in my configuration.nix
After a lot of search i found out how to get the tunnel credentials file going:
cloudflared tunnel token <tunnel-name/id>
echo | base64 -d
save the output in /home/<username>/.cloudflared/<tunnel-id>.json
Now the only problem remaining is: the cloudflared service just CANNOT manage to find the damn file somehow. How do i know? I used: journalctl -u <service-name> and its logs is filled with: tunnel credentials file <...> doesn't exist or is not a file
I just cannot find out why it cant find the file itself since i have confirmed the file exists at the exact place i have marked.
The cloudflared user won’t have directory listing permissions for your home directory. Create a /etc/secrets or such, put the file in there, and chown it so cloudflared has access.
Ahh I see, i did chmod to allow public read access to the file but i think i didn’t chown it. I’ll try that first, if even that doesn’t work I’ll move it to /etc.
Thanks for the tip, I’ll reply when i try it out.
I think this is probably why this isn’t working, your home directory should not have a+x set.
Hence my suggestion to put it in /etc, which is globally readable without requiring any weird file permissions on your user directory that may or may not be harmful to your privacy
Welp putting the credentials file inside /etc did help remove that error, but it seems i still cannot connect to my tunnel. It just says “context cancelled” and closes the connection within like seconds of me starting the service.
holy … this just worked. I dont know what’s wrong with the current stable’s service but i guess this will have to do for now, until i get flakes or something idk. thank you.
