I have an existing NixOS configuration:
{ pkgs, lib }:
with lib;
imports = [
# <nixpkgs/nixos/modules/profiles/qemu-guest.nix>
config = {
fileSystems."/" = {
device = "/dev/disk/by-label/nixos";
fsType = "ext4";
autoResize = true;
boot.growPartition = true;
boot.kernelParams = [ "console=ttyS0" ];
boot.loader.grub.device = "/dev/vda";
boot.loader.timeout = 0;
networking = {
hostName = "ci";
console.keyMap = "fr";
users.users.alice = {
initialPassword = "alice";
isNormalUser = true;
extraGroups = [ "wheel" ];
networking.firewall.enable = false;
security.sudo.wheelNeedsPassword = false;
system.stateVersion = "23.11";
environment.systemPackages = with pkgs; [ hello ];
I have tried to wrap it up in deploy-rs:
description = "deployment";
deploy-rs.url = "github:serokell/deploy-rs";
outputs = { self, nixpkgs, flake-utils, deploy-rs }:
flake-utils.lib.eachSystem [ flake-utils.lib.system.x86_64-linux ]
(system:
# nixpkgs with deploy-rs overlay but force the nixpkgs package
deployPkgs = import nixpkgs {
inherit system;
overlays = [
deploy-rs.overlay
(self: super: { deploy-rs = { inherit (pkgs) deploy-rs; lib = super.deploy-rs.lib; }; })
rec
nixosConfigurations = {
bare = nixpkgs.lib.nixosSystem {
inherit system;
modules = [ ./bare.nix ];
deploy = {
nodes = {
bare = {
hostname = "localhost";
sshUser = "alice";
sshOpts = [ "-p" "2222" ];
remoteBuild = false;
profiles.system = {
user = "root";
path = deployPkgs.deploy-rs.lib.${system}.activate.nixos self.nixosConfigurations.bare;
checks = builtins.mapAttrs (system: deployLib: deployLib.deployChecks self.deploy) deploy-rs.lib;
devShell = pkgs.mkShell {
buildInputs = [ pkgs.deploy-rs ];
inputsFrom = [];
But it fails strangely:
deploy '.#bare' -d
🚀 ❓ [deploy] [DEBUG] Checking for flake support
🚀 ℹ [deploy] [INFO] Running checks for flake in .
error:
… while checking flake output 'nixosConfigurations'
at /nix/store/hwsdv71bmaqvzbii5viryxc8slw4vr5v-source/lib.nix:73:15:
72| {
73| ${key} = (attrs.${key} or { })
74| // (appendSystem key system ret);
… while checking the NixOS configuration 'nixosConfigurations.x86_64-linux'
at /nix/store/hwsdv71bmaqvzbii5viryxc8slw4vr5v-source/lib.nix:69:24:
68| then (pushDownSystem system (attrs.hydraJobs or { }) ret.hydraJobs)
69| else { ${system} = ret.${key}; };
70| in
error: attribute 'config' in selection path 'config.system.build.toplevel' not found
🚀 ❌ [deploy] [ERROR] Failed to check deployment: Nix checking command resulted in a bad exit code: Some(1)
I don’t get the error as bare.nix has a config attribute.
Any hint about what’s missing/wrong?
