Hello,
I’m getting started with nix
for Haskell using haskell-flake
. When I run nix build
, some of my tests fail because they can’t find the file I’m loading as part of the test, even though the file is in the project root folder.
I’m assuming that the haskell-flake
tooling is filtering these files out of the src
because they’re JSON, how can I include them for the testing phase?
The tests succeed if I use nix develop
and then cabal test
You forgot to git-add the files most likely.
I confirmed that the files are tracked in git
In that case, a minimal example or the actual code would be helpful.
For the Haskell build, I’m using pretty boilerplate haskell-flake
, that’s why I’m thinking it probably has some filtering of files built-in.
This is the summarized flake:
description = "The Haskell library for interaction with the Zcash protocol";
nixpkgs.url = "github:nixos/nixpkgs/nixpkgs-unstable";
haskell-flake.url = "github:srid/haskell-flake";
rust-overlay = {
url = "github:oxalica/rust-overlay";
crane.url = "github:ipetkov/crane";
foreign-rust.url = "git+https://code.vergara.tech/Vergara_Tech/haskell-foreign-rust?ref=main";
hexstring.url = "git+https://code.vergara.tech/Vergara_Tech/haskell-hexstring?ref=master";
outputs = inputs @ {
self,
nixpkgs,
flake-parts,
rust-overlay,
crane,
foreign-rust,
hexstring,
flake-parts.lib.mkFlake {inherit inputs;} {
systems = nixpkgs.lib.systems.flakeExposed;
imports = [inputs.haskell-flake.flakeModule];
perSystem = {
self',
pkgs,
config,
inputs',
system,
}: let
craneLib = (inputs.crane.mkLib pkgs).overrideToolchain (p: p.rust-bin.selectLatestNightlyWith (toolchain: toolchain.default));
zcashwrapper = <summarized derivation>
_module.args.pkgs = import inputs.nixpkgs {
inherit system;
overlays = [(import inputs.rust-overlay)];
haskellProjects.default = {
packages = {
foreign-rust.source = inputs.foreign-rust;
hexstring.source = inputs.hexstring;
settings = {
rustzcash_wrapper.custom = _: zcashwrapper pkgs;
borsh = {
broken = false;
foreign-rust = {
check = false;
devShell = {
# haskell-flake doesn't set the default package, but you can do it here.
packages.default = self'.packages.zcash-haskell;
When I say a minimal example, I meant one that we could use to build and verify the behavior you’re seeing
Here is a MWE.
nix build
fails on checkPhase
nix develop
, cabal test
succeeds.
