Hi, I am a beginner of NixOS (about 2 weeks usage) and just experiencing flake from yesterday.
I want to use flake for my configuration.nix
, but it keeps throwing an error when I run sudo nixos-rebuild switch
error: cannot look up '<nixpkgs>' in pure evaluation mode (use '--impure' to override)
I appended the --impure flag and all run just fine, but I don’t want that.
I think it is caused by some of my local derivation .nix
file, below is just one of the example.
Inside /etc/nixos/doasedit-1.0.6
directory, I have a script called doasedit
which is installed with doasedit.nix
as shown below:
with import <nixpkgs> {}; # bring all of Nixpkgs into scope
stdenv.mkDerivation rec {
name = "doasedit-1.0.6";
src = ./.;
installPhase = ''
mkdir -p $out/bin
cp doasedit $out/bin
The above doasedit.nix
file is imported and installed into /etc/nixos/doas-config.nix
as shown below:
{ config, pkgs, ... }:
doas-sudo-shim
(import ./doasedit-1.0.6/doasedit.nix)
security.doas.enable = true;
security.sudo.enable = false;
# some other doas config ...
The above /etc/nixos/doas-config.nix
is imported into configuration.nix
to set doas related changes.
Because of the --impure
issue, now I am rewriting the doasedit.nix
to be doasedit-flake.nix
as below:
description = "doasedit flake";
inputs.nixpkgs.url = "nixpkgs/nixos-23.11";
outputs = { self, nixpkgs }@inputs:
system = "x86_64-linux";
inherit (pkgs) stdenv lib;
packages.${system}.default = pkgs.stdenv.mkDerivation {
src = ./.;
installPhase = ''
mkdir -p $out/bin
The /etc/nixos/flake.nix
I am using:
description = "NixOS Flake";
nixpkgs.url = "github:NixOS/nixpkgs/nixos-23.11";
nixpkgs-unstable.url = "github:NixOS/nixpkgs/nixos-unstable";
outputs = { self , nixpkgs , nixpkgs-unstable , ... }@inputs: {
nixosConfigurations = {
"nixos" = nixpkgs.lib.nixosSystem {
specialArgs = { inherit inputs; };
modules = [
./configuration.nix
I do not know how to import the doasedit-flake.nix
into doas-config.nix
or configuration.nix
or /etc/nixos/flake.nix
I googled and find something about specialArgs = { inherit inputs; };
in /etc/nixos/flake.nix
, but I cannot get it to work. Or maybe it is just irrelevant.
Or is it not suitable to rewrite the doasedit.nix
with flake in this case?
Please help!! Thank you very much!
