I installed mold using home-manager like this:
home.packages = with pkgs; [
mold
home.file.".cargo/config.toml".text = ''
[target.x86_64-unknown-linux-gnu]
linker = "clang"
rustflags = ["-C", "link-arg=-fuse-ld=${pkgs.mold}/bin/mold"]
This works fine as long as I’m building pure Rust projects. When I tried to build something that needed libpq, compilation failed saying libpq.so.5 not found.
The issue goes away if I remove the cargo/config.toml.
Any idea how to fix this?
raphi
April 7, 2022, 9:35am
2
Apparently we do have a wrapped lld now, but it’s not in pkgs.lld, it’s in pks.llvmPackages.bintools.
Let me restate the solution more clearly:
There are two packages that provide LLD in nixpkgs: pkgs.lld and pkgs.llvmPackages.bintools . The former is unwrapped, and doesn’t, eg, set rpath. The latter is wrapped, and just works. So, the following fixed the issue I was having with compiling Rust code:
matklad/config@440b1e2
Source: LLD linker does not have required nixpkgs wrapper script and flags · Issue #24744 · NixOS/nixpkgs · GitHub
I just found the same issue as the OP.
I managed to comeup with a fix: I’m not sure this is the best way to go, but it does make mold work. I’ve applied this in a small rust project: flake devShell: Use gcc12 and link using mold (4cd5ad13) · Commits · Roosemberth Palacios / mtt · GitLab
Basically, it consist of wrapping mold binaries with bintools-wrapper/ld-wrapper.sh:
devShells = forAllSystems (pkgs: with pkgs; let
bintools-wrapper = "${nixpkgs}/pkgs/build-support/bintools-wrapper";
mold' = symlinkJoin {
name = "mold";
paths = [ mold ];
nativeBuildInputs = [ pkgs.makeWrapper ];
suffixSalt = lib.replaceStrings ["-" "."] ["_" "_"] targetPlatform.config;
postBuild = ''
for bin in ${mold}/bin/*; do
rm $out/bin/"$(basename "$bin")"
export prog="$bin"
substituteAll "${bintools-wrapper}/ld-wrapper.sh" $out/bin/"$(basename "$bin")"
chmod +x $out/bin/"$(basename "$bin")"
mkdir -p $out/nix-support
substituteAll "${bintools-wrapper}/add-flags.sh" $out/nix-support/add-flags.sh
substituteAll "${bintools-wrapper}/add-hardening.sh" $out/nix-support/add-hardening.sh
substituteAll "${bintools-wrapper}/../wrapper-common/utils.bash" $out/nix-support/utils.bash
done
default = mkShell.override({ stdenv = gcc12Stdenv; }) {
NIX_CFLAGS_LINK = "-fuse-ld=mold";
packages = [ cargo clippy gdb rust-analyzer rustc rustfmt mold' ];
inputsFrom = [ mtt ];
I added a useMoldLinker stdenv adapter stdenvAdapters: add useMoldLinker · NixOS/nixpkgs@299a7bd · GitHub
EDIT there’s now mold-wrapped
dpc
October 12, 2023, 11:09pm
7
dpc
November 14, 2025, 5:18pm
8
