Warning: rant incoming, but I feel like this sort of thing is not uncommon, and I haven’t seen that much progress since I started using nix back in ~late 2020.
Today I wanted to add a package. Specifically, sshfs-fuse.
The first thing to do is of course to find the exact package name with nix search
nix search sshfs
error: experimental Nix feature 'nix-command' is disabled; use '--extra-experimental-features nix-command' to override
and trying to follow the instructions it gives you just leads you to a dead end:
nix search --extra-experimental-features nix-command --extra-experimental-features flakes sshfs
error: cannot find flake 'flake:sshfs' in the flake registries
Thankfully, Google has my back, and “nixpkgs sshfs” gets me on my way. The package name is “sshfs-fuse” and I add that to my .nixpkgs/darwin-configuration.nix
$ darwin-rebuild switch
error: nixVersions.nix_2_4 has been removed
Well that sucks. It would have been nice if it gave me any kind of inkling of what I’m supposed to do, or even what the current version is.
Googling “error: nixVersions.nix_2_4 has been removed” turns up one bug report (The rnix-lsp from nix-community - GithubHelp) with no solutions. Variations were no immediate help either.
Googling “Nix 2.4” shows a release announcement in November of 2021. So this is being deprecated and going EOL in a year with no replacement being specified!?!?
Googling “nix version” gives me the front page and “NixOS 22.05 released.” Well that’s obviously not it.
Googling “nix current version” gives me the downloads page (Download Nix / NixOS | Nix & NixOS). Ok, so the current version of nix is 2.11.1. I try replacing nix_2_4 with nix_2_11 in my .nixpkgs/darwin-configuration.nix
error: attribute 'nix_2_11' missing
at /Users/spease/.nixpkgs/darwin-configuration.nix:95:17:
94| nix.nixPath = [ "darwin=$HOME/.nix-defexpr/channels/darwin" "nixpkgs=$HOME/projects/nixpkgs" ];
95| nix.package = pkgs.nix_2_11;
96| nix.extraOptions = ''
Maybe I need to run nix-channel --update
Nope, same error.
Checking the release notes for 22.05 says that it’s using nix package manager 2.8. Ok, let’s try that.
error: attribute 'nix_2_8' missing
95| nix.package = pkgs.nix_2_8;
I see in one of my google searches there was a nix package search - NixOS Search. Ok, let’s try that…nope, it says 2.8 and 2.11 too. Maybe I need the full version string?
error: attribute 'nix_2_8_1' missing
95| nix.package = pkgs.nix_2_8_1;
Ok, let’s try just pkgs.nix
trace: warning: The option `users.nix.configureBuildUsers' defined in `/Users/spease/.nixpkgs/darwin-configuration.nix' has been renamed to `nix.configureBuildUsers'.
error: attribute 'installApplication' missing
at /Users/spease/.nixpkgs/overlays/carthage.nix:3:1:
2|
3| darwin.installApplication rec {
4| pname = "carthage";
Well, it accepts that, but now my overlays seem to be broken. I vaguely recall running into this issue - and apparently nobody who saw my post knew how to fix it.
So it looks like I’m stuck with potentially hours or days of troubleshooting to fix that error, or implicitly removing all those applications.
Attempting to move things out of the darwin
namespace to the top-level and renaming installApplication to darwinInstallApplication, I get a couple more obvious error messages. Then I get:
error: value is a string while a list was expected
at /nix/store/qwg6sqp8vy46mc3i4p90f51snfs7laxi-nixpkgs-22.11pre415372.7b06206fa24/nixpkgs/lib/lists.nix:36:20:
35| */
36| forEach = xs: f: map f xs;
37|
Showing a trace generates pages of low-level error messages. I have no clue what’s going on. Is it something to do with forEach changing? Is it an issue with the maintainers field of one of the packages using installApplication? I don’t see any packages listed. Is it because something thinks darwinInstallApplication is a derivation rather than a derivation-maker? That’s my best guess.
At this point I’m just fed up. All I wanted to do was add one package to my system, and instead I got bogged down in fixing an override. The process of adding overrides is unreasonably complicated (There are at least 4 functions, not counting language-specific ones, none of which seemed to work for adding a package to the darwin
namespace, and it would seem that things are too complex and the experts are too few.
Is nix supposed to be just generally unusable and not targeted at people if you aren’t developing nixpkgs? Because the goals sound great, but I’ve been trying to use it for years, and it seems like the usability issues for even basic use never stop. And the level of knowledge required to maintain even a basic system and work around eg missing binary packages is apparently far beyond what I would consider the “casual user whose life doesn’t revolve around nix” level.
To preemptively address the objection that my installApplication
derivation isn’t “basic use” - I’d say that’s correct, but it also seemed necessary given that several common applications eg firefox couldn’t be installed with nix on macOS. Since the level of knowledge required to create a nix derivation was well in excess of that for homebrew, I figured I would make something that would make it simpler. However, it broke before I could try to upstream it, and I simply haven’t had the massive amount of time nix seems to require to do anything meaningful with it to fix it.
Having declarative package management sounds great, but the current expression of it just has far too many edge cases (“the exception is the rule”) and the practical steps required to do things is just too complex to remember, and the underlying implementation concepts somewhat intuitive with what’s actually being expressed. Eg you’re describing a package, but it’s actually a function, and because of that you can’t just “override” by setting the variables of that package. You have to use more function calls, and know when to use which override function call, and now the simplicity of the language is lost in the complexity of the API.
