I’m taking my first steps with Nix/NixOS, setting it up on a Jetson AGX SBC with jetpack-nixos. The base set-up is working fine: I have a bootable OS with a configuration.nix
that lists some essential services (ssh, tailscale, etc) and packages (git, screen, ripgrep, etc), configures users, etc.
I now want to use this system for more traditional development, so I figured that it would be clean to have a shell.nix
in my project’s workdir that sets up a FHS env with tools and libraries I need to be available at more traditional locations (because I’m using precompiled binaries, and software that expects libraries to be easily discoverable). This includes packages from jetpack-nixos, however, where in configuration.nix
I could just do fetchTarball "http://..."
, in shell.nix
I seem to need to inherit (pkgs) bunch of stuff
for these imports to work, or nix-shell
errors with e.g.
error:
at /builtin/derivation.nix:9:12: (source not available)
… while evaluating derivation 'Julia-shell-env'
whose name attribute is located at /nix/store/c1nvlh9lqqvk9syr7pdjq3q7g5akwv06-nixos-23.11pre-git/nixos/pkgs/stdenv/generic/make-derivation.nix:348:7
… while evaluating attribute 'shellHook' of derivation 'Julia-shell-env'
at /nix/store/c1nvlh9lqqvk9syr7pdjq3q7g5akwv06-nixos-23.11pre-git/nixos/pkgs/build-support/build-fhsenv-bubblewrap/default.nix:231:7:
230| env = runCommandLocal "${name}-shell-env" {
231| shellHook = bwrapCmd {};
232| } ''
error: function 'anonymous lambda' called without required argument 'fetchurl'
at /nix/store/nszwggq88davccbn18py5j30hnmzhm7q-source/default.nix:1:1:
1| { callPackage
2| , callPackages
Working version of shell.nix
jetpack = import (builtins.fetchTarball "https://github.com/anduril/jetpack-nixos/archive/master.tar.gz") {
inherit (pkgs) pkgs stdenv lib fetchurl writeShellApplication runtimeShell stdenvNoCC runCommand callPackage callPackages python3 bzip2_1_1 dtc dpkg;
fhs = pkgs.buildFHSUserEnv {
name = "Julia";
targetPkgs = pkgs: with pkgs; [
glibc
stdenv.cc.cc
jetpack.l4t-cuda
runScript = "zsh";
in fhs.env
I feel like I’m doing something wrong, or at least un-idiomatic here, so any suggestions are appreciated!
❯ nix-info -m
- system: `"aarch64-linux"`
- host os: `Linux 5.10.104, NixOS, 23.11 (Tapir), 23.11pre-git`
- multi-user?: `yes`
- sandbox: `yes`
- version: `nix-env (Nix) 2.18.1`
- nixpkgs: `/nix/var/nix/profiles/per-user/root/channels/nixos`
