I have an aarch64 laptop and I want to run nixos-rebuild on that host and build for and deploy to a x86_64-linux machine. So I have spent some time researching and reading up on how to do this.
However I must be missing something because I get an error complaining that “i686 Linux package set can only be used with the x86 family”
I have added the below config to my host system config
boot.binfmt.emulatedSystems = [ "x86_64-linux" ];
nix.settings.extra-platforms = config.boot.binfmt.emulatedSystems;
The flake for my remote x86_64 machine is
description = "NixOS configuration";
nixpkgs = {
url = "github:NixOS/nixpkgs/nixos-24.05";
sops-nix = {
url = "github:Mic92/sops-nix";
outputs = { nixpkgs, sops-nix, ... }: {
nixosConfigurations = {
# Native build on the machine
Test = nixpkgs.lib.nixosSystem {
system = "x86_64-linux";
modules = [
sops-nix.nixosModules.sops
# import config
./configuration.nix
# Build on aarch64 for x86_64
Test-from-aarch64 = nixpkgs.lib.nixosSystem {
modules = [
# import config
./configuration.nix
# this is the achitecture we build from
nixpkgs.buildPlatform = "aarch64-linux";
# this is the architecture of the target system
nixpkgs.hostPlatform = "x86_64-linux";
When I run the nixos-rebuild command
nixos-rebuild switch --fast --flake .#Test-from-aarch64 --build-host localhost --target-host target-machine --option eval-cache false
I get
error:
at /nix/store/2lvj8bm21ymxra61dqrc4xpzr8njgywj-source/lib/attrsets.nix:1575:11:
1574| || pred here (elemAt values 1) (head values) then
1575| head values
1576| else
at /nix/store/2lvj8bm21ymxra61dqrc4xpzr8njgywj-source/lib/modules.nix:809:9:
808| in warnDeprecation opt //
809| { value = builtins.addErrorContext "while evaluating the option `${showOption loc}':" value;
810| inherit (res.defsFinal') highestPrio;
error: i686 Linux package set can only be used with the x86 family.
What do you think I am missing here?
