CDN
August 27, 2024, 3:44am
1
Hello everyone, I’m having trouble using NUR in my NixOS configuration after introducing it in my flake.nix. Here’s my setup:
flake.nix
inputs {
nur.url = "github:nix-community/NUR";
outputs = { self, nixpkgs, home-manager, nur, ... }@inputs: {
nixosConfigurations.default = nixpkgs.lib.nixosSystem {
specialArgs = {
inherit inputs nur;
modules = [
./hosts/default/configuration.nix
configuration.nix
{ pkgs, lib, inputs, nur, ... }:
nur.repos.mic92.hello-nur
When I try to rebuild, I get the error: attribute 'repos' missing. Any insights on what might be going wrong?
Using NUR with flakes is silly, NUR was intended for people who don’t use flakes.
Just use the direct upstream flake itself! In this case - GitHub - Mic92/nur-packages: My personal NUR repository
And the full list of repos is at NUR/repos.json at d39c7ced498d546513270b314d682ac5d7de734d · nix-community/NUR · GitHub
CDN
August 27, 2024, 1:36pm
3
Oh! I just started with NixOS a few days ago and didn’t realize that. Do you mean to use the upstream flake as an input, like this:
flake.nix
inputs {
# nur.url = "github:nix-community/NUR";
mic92.url = "github:Mic92/nur-packages";
Is this the correct approach? Also, how should I export these packages so that I can use them in both my NixOS configuration and Home Manager? (I tried to find some templates on GitHub for direct usage, but their output sections were quite complex, and I’m having trouble figuring out which parts to use.)
Yes, since the upstream repo has a flake.nix, that makes it a flake, so you can use it as an input directly.
Then you can use whichever packages, modules, etc. from that flake input.
CDN
August 27, 2024, 4:46pm
5
Thanks very much, @waffle8946 ! Now I understand how to do it.
However, I still don’t quite understand why using upstream flakes directly is better than using NUR in flakes. If you don’t mind, could you briefly explain why?
CDN
August 27, 2024, 4:56pm
6
If anyone stumbles upon this post and wants to know how to do it, here is my configuration:
flake.nix
home-manager = {
outputs = { self, nixpkgs, home-manager, mic92, ... }@inputs: {
specialArgs = {
inherit inputs;
modules = [
configuration.nix
{ pkgs, lib, inputs, config, ... }:
home-manager = {
useGlobalPkgs = true;
extraSpecialArgs = { inherit pkgs inputs; };
users = {
"username" = import ./home.nix;
inputs.mic92.packages.x86_64-linux.hello-nur
home.nix
{ pkgs, inputs, config, ... }:
home.packages = with pkgs; [
This way, you can use packages from another flake in both your NixOS configuration and Home Manager. Although, this configuration almost certainly has some unwise parts (like I should probably move x86_64-linux to flake.nix).
CDN
August 27, 2024, 5:12pm
7
Additionally, if anyone insists on integrating NUR with flakes, you can try the following configurations:
Method 1: Adding an overlay upon nixpkgs
flake.nix
specialArgs = {
inherit inputs;
modules = [
nixpkgs.overlays = [ nur.overlay ];
configuration.nix
home-manager = {
extraSpecialArgs = { inherit pkgs; };
users = {
In home.nix under home.packages, you can also use nur.repos.mic92.hello-nur.
Method 2: Directly passing the inputs (similar to using upstream flakes directly)
flake.nix
specialArgs = {
inherit inputs;
modules = [
configuration.nix
home-manager = {
users = {
config.nur.repos.mic92.hello-nur
home.nix
osConfig.nur.repos.mic92.hello-nur
I haven’t figured out the differences between them yet, but they both seem to work…
I’m not sure what is different, but I had to change this slightly to work for me. My flake.nix looks like this:
nixosConfigurations = {
default = let
username = "daneb";
system = "x86_64-linux";
specialArgs = {inherit inputs username system;};
inherit specialArgs;
modules = [
{nixpkgs.overlays = [inputs.nur.overlays.default];}
home-manager.extraSpecialArgs = specialArgs;
# ... other home-manager configuration
# ... other modules
