This is part of a larger problem, compiling truffleruby on nixos, which uses a tool called mx.
The tool downloads openjdk-21, which has jdk binaries. I would like to make all of them run so I can continue with a truffleruby build.
This is the error I get when running java
$ ~/.mx/jdks/labsjdk-ce-21-jvmci-23.1-b15/bin/java
bash: /home/razetime/.mx/jdks/labsjdk-ce-21-jvmci-23.1-b15/bin/java: cannot execute: required file not found
As an attempt to make sure it recognizes my system libraries, I have nixos-rebuild
config set LD_LIBRARY_PATH
every build:
I am attempting to figure out a way to patch the file(s) for jdk with patchelf
, but I am unsure of what fields to patch with the given output. I am also open to knowing what other methods i can use to run it.
$ readelf -d java
Dynamic section at offset 0x1d08 contains 33 entries:
Tag Type Name/Value
0x0000000000000003 (PLTGOT) 0x2f88
0x0000000000000002 (PLTRELSZ) 288 (bytes)
0x0000000000000017 (JMPREL) 0x7c0
0x0000000000000014 (PLTREL) RELA
0x0000000000000007 (RELA) 0x718
0x0000000000000008 (RELASZ) 168 (bytes)
0x0000000000000009 (RELAENT) 24 (bytes)
0x000000006ffffff9 (RELACOUNT) 3
0x0000000000000015 (DEBUG) 0x0
0x0000000000000006 (SYMTAB) 0x278
0x000000000000000b (SYMENT) 24 (bytes)
0x0000000000000005 (STRTAB) 0x470
0x000000000000000a (STRSZ) 381 (bytes)
0x000000006ffffef5 (GNU_HASH) 0x5f0
0x0000000000000004 (HASH) 0x628
0x0000000000000001 (NEEDED) Shared library: [libz.so.1]
0x0000000000000001 (NEEDED) Shared library: [libjli.so]
0x0000000000000001 (NEEDED) Shared library: [libpthread.so.0]
0x0000000000000001 (NEEDED) Shared library: [libdl.so.2]
0x0000000000000001 (NEEDED) Shared library: [libc.so.6]
0x000000000000000c (INIT) 0x8e0
0x000000000000000d (FINI) 0xd0c
0x000000000000001a (FINI_ARRAY) 0x2cf8
0x000000000000001c (FINI_ARRAYSZ) 8 (bytes)
0x0000000000000019 (INIT_ARRAY) 0x2d00
0x000000000000001b (INIT_ARRAYSZ) 8 (bytes)
0x000000000000001d (RUNPATH) Library runpath: [$ORIGIN:$ORIGIN/../lib]
0x000000000000001e (FLAGS) BIND_NOW
0x000000006ffffffb (FLAGS_1) Flags: NOW PIE
0x000000006ffffff0 (VERSYM) 0x6c8
0x000000006ffffffe (VERNEED) 0x6f4
0x000000006fffffff (VERNEEDNUM) 1
0x0000000000000000 (NULL) 0x0
