I was going to tackle my vscode configuration on my nixOS system. Then I had a realization that I use vscode on non-nix systems as well.
Is there any reason I can’t just use the built in “settings sync” that vscode has? Is there any extra configuration needed for it to work properly? I turned it on, and it “seems” to work. But I wanted to confirm so I don’t break my config on all my systems.
I’m not worried about the whole “reproducible builds” aspect.
Thanks.
Edit - I spoke too soon. Seems like some settings came through. And some extensions.
Small update. So I have moved to using the vscode-fhs package. But for some reason this machine will only pull a partial of my config and extensions. I have to be missing something.
EDIT - I blew away all code settings, reinstalled, and tried again. Same issue. 17 of 79 extensions show up, and only a handful of settings. sigh.
