With localSystem = x86-64-linux
/ crossSystem = aarch64-linux
, I’m having trouble with finding libstdc++.so.6
I can see in the nix log that the GCC lib path is wrong - it’s .../lib/
when it needs to be .../aarch64-unknown-linux-gnu/lib
I’m using flake-utils.lib.eachDefaultSystem
with crossSystem = "aarch64-linux"
Package file is like so:
src,
lib,
stdenv,
autoPatchelfHook,
llvmPackages_17,
llvmPackages_17.stdenv.mkDerivation rec {
name = "mypkg";
inherit src;
nativeBuildInputs = [autoPatchelfHook];
buildInputs = [stdenv.cc.cc.lib];
Changing stdenv.cc.cc.lib
to "${stdenv.cc.cc.lib}/aarch64-unknown-linux-gnu"
works, but is clearly not right.
Am I missing something obvious here or is there something special I need to do for authPatchelfHook
when cross-compiling?
'libs': [PosixPath('/nix/store/garx7rbwr0i9if5sn2q3gaswwraywx08-compiler-rt-libc-aarch64-unknown-linux-gnu-17.0.6-dev/lib'),
PosixPath('/nix/store/84dpxzkp68lznd6ll5i6ilz5yjkjnvc7-compiler-rt-libc-aarch64-unknown-linux-gnu-17.0.6/lib'),
PosixPath('/nix/store/srygzvlbvr4drgqylx83hr9jd0g47swn-aarch64-unknown-linux-gnu-gcc-13.2.0-lib/lib')],
'paths': [PosixPath('/nix/store/7110z5rh9dqx21qrgvn1f6hwflyasb1n-mypkg-aarch64-unknown-linux-gnu')],
'recursive': True,
'runtime_dependencies': []}
searching for dependencies of /nix/store/7110z5rh9dqx21qrgvn1f6hwflyasb1n-mypkg-aarch64-unknown-linux-gnu/lib/libmypkg.so
libstdc++.so.6 -> not found!
libgcc_s.so.1 -> not found!
auto-patchelf: 2 dependencies could not be satisfied
does not exist
/nix/store/srygzvlbvr4drgqylx83hr9jd0g47swn-aarch64-unknown-linux-gnu-gcc-13.2.0-lib/aarch64-unknown-linux-gnu/lib
does exist
