I installed a package in NixOS, and I found a bug. Supposedly the fix for the bug is in the latest code in the repo. So I want to grab the latest code, and build it locally, perhaps doing some additional development.
I hoped I could take the default.nix from NixOS/nixpkgs, tweak it to get the latest version of the code from the repo, and use it to launch a nix shell. However, the derivations from NixOS/nixpkgs expect a lot of stuff to passed to them, so using them directly doesn’t work.
$ nix-shell
error: cannot evaluate a function that has an argument without a value ('lib')
Nix attempted to evaluate a function as a top level expression; in
this case it must have its arguments supplied either by default
values, or passed explicitly with '--arg' or '--argstr'. See
https://nixos.org/manual/nix/stable/#ss-functions.
at /home/amy/waybar-amy/default.nix:1:3:
1| { lib
2| , stdenv
Is there a magic incantation that will let me run nix-shell on this default.nix? Failing that, how do I modify it? (Note: I put lib.fakeSha256 there temporarily; I know I can get the real value when it tries to fetch the source.) I’ve only written a few simple nix derivations; writing this one from scratch is beyond my skills.
$ cat default.nix
{ lib
, stdenv
, fetchFromGitHub
, meson
, pkg-config
, ninja
, wrapGAppsHook
, wayland
, wlroots
, gtkmm3
, libsigcxx
, jsoncpp
, scdoc
, spdlog
, gtk-layer-shell
, howard-hinnant-date
, libxkbcommon
, traySupport ? true, libdbusmenu-gtk3
, pulseSupport ? true, libpulseaudio
, sndioSupport ? true, sndio
, nlSupport ? true, libnl
, udevSupport ? true, udev
, evdevSupport ? true, libevdev
, swaySupport ? true, sway
, mpdSupport ? true, libmpdclient
, rfkillSupport ? true
, withMediaPlayer ? false, glib, gobject-introspection, python3, python38Packages, playerctl
stdenv.mkDerivation rec {
pname = "waybar";
version = "0.9.8";
src = fetchFromGitHub {
owner = "Alexays";
repo = "Waybar";
rev = master;
sha256 = lib.fakeSha256;
nativeBuildInputs = [
meson ninja pkg-config scdoc wrapGAppsHook
] ++ lib.optional withMediaPlayer gobject-introspection;
propagatedBuildInputs = lib.optionals withMediaPlayer [
glib
playerctl
python38Packages.pygobject3
strictDeps = false;
buildInputs = with lib;
[ wayland wlroots gtkmm3 libsigcxx jsoncpp spdlog gtk-layer-shell howard-hinnant-date libxkbcommon ]
++ optional traySupport libdbusmenu-gtk3
++ optional pulseSupport libpulseaudio
++ optional sndioSupport sndio
++ optional nlSupport libnl
++ optional udevSupport udev
++ optional evdevSupport libevdev
++ optional swaySupport sway
++ optional mpdSupport libmpdclient;
mesonFlags = (lib.mapAttrsToList
(option: enable: "-D${option}=${if enable then "enabled" else "disabled"}")
dbusmenu-gtk = traySupport;
pulseaudio = pulseSupport;
sndio = sndioSupport;
libnl = nlSupport;
libudev = udevSupport;
mpd = mpdSupport;
rfkill = rfkillSupport;
"-Dsystemd=disabled"
"-Dgtk-layer-shell=enabled"
"-Dman-pages=enabled"
preFixup = lib.optionalString withMediaPlayer ''
cp $src/resources/custom_modules/mediaplayer.py $out/bin/waybar-mediaplayer.py
wrapProgram $out/bin/waybar-mediaplayer.py \
--prefix PYTHONPATH : "$PYTHONPATH:$out/${python3.sitePackages}"
meta = with lib; {
description = "Highly customizable Wayland bar for Sway and Wlroots based compositors";
license = licenses.mit;
maintainers = with maintainers; [ FlorianFranzen minijackson synthetica lovesegfault ];
platforms = platforms.unix;
homepage = "https://github.com/alexays/waybar";
