I’m converting my nix code from flake-utils to flake-parts. The code generates images for flashing on aarch64-linux devices. Those devices are described in the top-level flake.nix in the nixosConfigurations attribute.
flake-utils was adding the (build) system name to nixosConfigurations, which was breaking nix flake check. But apart from that, everything looked neat and simple. The system value was available inside the nixosConfiguration definition, which used it for individual configurations:
With flake-parts (or if I just stop using flake-utils), system is no longer visible in nixosConfiguration. That leaves me with several options, neither of which is very appealing.
Use separate configurations based on the build system. For instance, devkit splits into x86_64-linux-devkit and aarch64-linux-devkit. That’s what flake-utils was doing behind the scenes, but now it becomes visible and misleading, as x86_64-linux-devkit is an image for aarch64-linux built on an x86_64-linux machine.
Limit the build system to x86_64-linux. That would interfere with our plan to use Asahi Linux (aarch64-linux) for the build eventually.
Use impure build so I can do simply import nixpkgs; without specifying the build system.
I hope to find some way do define nixosConfigurations without depending on system. That would be the best.
After spending a lot of time on different approaches, I realized a simple fact. nixosConfiguration is too rigid. It doesn’t accept any information about the build system, whether it’s the host platform or the build platform. The host platform is known, but the build platform can only be recovered using means that are considered impure.
Indeed, let’s consider the packages output after flake-parts expansion:
Now it’s my turn to leave a late reply. It’s been a while - I have trouble understanding my own posts. I remember only that I had to standardize the build to x86_64-linux to get reproducible hashes. I could not use an aarch64-based laptop to build the “approved” OS images. Anyway, I left that job long ago. Yes, it sounds like the nixpkgs developers took an effort to make cross-compilation less frustrating, but I don’t have the time and hardware to verify it.
Here’s the “perpetual” link for the benefit of others: NixOS Search
