igel
1
- system: `"x86_64-linux"`
- host os: `Linux 5.15.43, NixOS, 22.05 (Quokka), 22.05.866.1f8d88087a3`
- multi-user?: `yes`
- sandbox: `yes`
- version: `nix-env (Nix) 2.8.1`
- channels(root): `"home-manager-22.05.tar.gz, nixos-22.05"`
- channels(usera): `""`
- nixpkgs: `/nix/var/nix/profiles/per-user/root/channels/nixos`
virtualisation = {
virtualbox = {
host = {
enable = true ;
enableExtensionPack = true ;
guest.enable = true ;
[ 0.670681] stage-1-init: [Fri Jun 17 05:24:40 UTC 2022] modprobe: ERROR: could not insert 'vboxsf': No such device
I can find modprobe vboxsf breaks boot · Issue #58127 · NixOS/nixpkgs · GitHub
is
boot.kernelPatches = [
name = "vbox-virt-conflict-config";
patch = null;
extraConfig = ''
VBOXGUEST n
still the (best) solution?
I do think your error is related to modprobe vboxsf breaks boot · Issue #58127 · NixOS/nixpkgs · GitHub all. Are there any messages in the log before the vboxsf line?
igel
3
here the lines before the error msg (or do you mean filtered to vbox?)
42825-[ 0.581797] zswap: loaded using pool lzo/zbud
42874-[ 0.582195] Key type ._fscrypt registered
42919-[ 0.582196] Key type .fscrypt registered
42963-[ 0.582196] Key type fscrypt-provisioning registered
43019-[ 0.582772] Freeing unused kernel image (initmem) memory: 1768K
43086-[ 0.591931] Write protecting the kernel read-only data: 22528k
43152-[ 0.592300] Freeing unused kernel image (text/rodata gap) memory: 2040K
43227-[ 0.592430] Freeing unused kernel image (rodata/data gap) memory: 880K
43301-[ 0.592433] Run /init as init process
43342-[ 0.592433] with arguments:
43375-[ 0.592434] /init
43400-[ 0.592434] with environment:
43435-[ 0.592435] HOME=/
43461-[ 0.592435] TERM=linux
43491-[ 0.592435] BOOT_IMAGE=(hd1,gpt1)//kernels/as6k49h3a5w3wzxa6mkfygqiwkk75zs8-linux-5.15.43-bzImage
43596-[ 0.603552] stage-1-init: [Fri Jun 17 05:24:40 UTC 2022] loading module dm-snapshot...
43686-[ 0.614895] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
43782-[ 0.618831] stage-1-init: [Fri Jun 17 05:24:40 UTC 2022] loading module vboxsf...
43867-[ 0.656025] vboxguest: loading out-of-tree module taints kernel.
43935-[ 0.657715] vboxguest: PCI device not found, probably running on physical hardware.
44022:[ 0.670681] stage-1-init: [Fri Jun 17 05:24:40 UTC 2022] modprobe: ERROR: could not insert 'vboxsf': No such device
44141-[ 0.671091] stage-1-init: [Fri Jun 17 05:24:40 UTC 2022] loading module dm_mod...
44226-[ 0.671615] stage-1-init: [Fri Jun 17 05:24:40 UTC 2022] running udev...
44302-[ 0.676389] stage-1-init: [Fri Jun 17 05:24:40 UTC 2022] Starting version 250.4
44385-[ 0.703849] rtc_cmos rtc_cmos: RTC can wake from S4
44440-[ 0.704992] rtc_cmos rtc_cmos: registered as rtc0
44493-[ 0.705003] rtc_cmos rtc_cmos: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
44583-[ 0.705118] cryptd: max_cpu_qlen set to 1000
[looks like] vbox is making the boot significantly longer and get Xserver to stop working → tty1 (taking it out of the config and UI is “fine”)
autra
4
I reproduce too on kernel 6.1.87, despite the commits referenced in the linked issue being merged.
I tested the workaround of boot.kernelPatches, but it didn’t fix it (but it did trigger a full rebuild of the linux kernel).
