VS Code and Nix IDE - newbie problems
I’m sure it will be obvious shortly: I’m not a dev. I started using NixOS last week and love building my configuration files but working without an IDE was driving me bonkers. I’ve previously done some amateur coding using VS Code so I want to keep using that as an IDE.
However, I really struggled to understand how to set up the VS Code environment so it actually worked.
Obviously, the VS Code extensions Nix Environment and Nix IDE were required. No problems there. However, I just got a bunch of errors after using them. Typically, the errors related to “cannot find language server” and “cannot find nixpkgs-fmt”. Unfortunately, the instructions didn’t provide enough details for me to figure out what to actually do. In particular, Nix IDE has a bunch of instructions under “Language Servers” and “Formatting”, but no explanation as to where you are supposed to put this code. I guess all the pros just know.
I think I’ve solved the problems through these two steps:
Step One
nixd1 and nixpkgs-fmt are NixOS packages which need to be added to your NixOS user environment. You can do tihs through sudo nix-shell -p nixd && sudo nix-shell -p nixpkgs-fmt, or add them to your configuration.nix file. I added them to vscode.nix which is imported by configuration.nix. The contents of vscode.nix are:
# vscode.nix
{ pkgs, ... }: {
    vscode # Microsoft VS Code
    nixpkgs-fmt # nix code formatter for nixpkgs
    nixd # nix Language Server Protocal (LSP)
    direnv #
  environment.sessionVariables.NIXOS_OZONE_WL = "1"; # required per nixos wiki page on VS Code
Step Two
The rest of the code is added to settings.json in VS Code. Use Ctrl + Shift + P and search for the file, then add the code. My settings.json file now includes:
    // Nix settings
    "nix.formatterPath": [
        "nixpkgs-fmt",
        "nixfmt",
        "treefmt",
        "--stdin",
        "{file}",
        "nix",
        "fmt",
    "nix.enableLanguageServer": true,
    "nix.serverPath": "nixd",
    "nix.serverSettings": {
        "nixd": {
            "formatting": {
                "command": [
                    "nixpkgs-fmt"
            "options": {
                // By default, this entriy will be read from `import <nixpkgs> { }`.
                // You can write arbitary Nix expressions here, to produce valid "options" declaration result.
                // Tip: for flake-based configuration, utilize `builtins.getFlake`
                "nixos": {
                    "expr": "(builtins.getFlake \"/absolute/path/to/flake\").nixosConfigurations.<name>.options"
                "home-manager": {
                    "expr": "(builtins.getFlake \"/absolute/path/to/flake\").homeConfigurations.<name>.options"
                // Tip: use ${workspaceFolder} variable to define path
                "nix-darwin": {
                    "expr": "(builtins.getFlake \"${workspaceFolder}/path/to/flake\").darwinConfigurations.<name>.options"
With those steps done, my .nix files are now being formatted, unused code is highlighted, obvious errors relating to syntax seem to be highlighted, and I’m getting some information relating to packages.
Just me?
It seems there is also support for options. I.e. they are presented as I’m typing, such as this:
However, if I add something that seems bogus, there are no error messages. For example, this code is nonsense, as the option requires a list of packages.
environment.gnome.excludePackages = 100;
And this just has a spelling error (missing the “k” in “kernel”):
boot.ernelModules = [ "kvm-intel" ];
However, no error is given for either by the IDE. Using nixos-rebuild catches the error in compile time, but I would have thought the IDE would catch it earlier.
Unresolved errors
I’m not sure if these are bugs in the IDE, or something I’m missing, but if I create an empty file like empty.nix and focus on it, the IDE spits out these errors:
I[16:08:50.948] 3992: → reply:textDocument/documentSymbol(272) AST is null on this unit, error: 3
[Error - 16:08:50] Request textDocument/documentSymbol failed.
Message: AST is null on this unit
Code: -32001
Code: -32001
I[16:08:51.599] 3992: ← textDocument/documentLink(273)
I[16:08:51.599] 3992: → reply:textDocument/documentLink(273) AST is null on this unit, error: 3
[Error - 16:08:51] Request textDocument/documentLink failed.
Code: -32001
I[16:08:51.849] 3992: ← textDocument/inlayHint(274)
I[16:08:51.849] 3992: → reply:textDocument/inlayHint(274) AST is null on this unit, error: 3
[Error - 16:08:51] Request textDocument/inlayHint failed.
Code: -32001
As soon as a single character is added to the file, the errors stop, so I suspect a bug.
Questions for more experienced users
  1. Did I get Step Two correct?
  2. Am I missing a setting for the IDE which would prevent bad inputs such as those listed above?
  3. Are the Code -32001 errors a bug, or another missed setting?
Thanks, non-noobs!
Heyo, also a noob, but also a maintainer of a language extension. From what I can see, this looks like a fault of the language extension, and not you. The “AST” mentioned in the error message is an abstract syntax tree, which is a representation of the contents of the file. Since the file is empty, the AST is null, and the language extension freaks out with errors.
Looks like the Nix IDE extension isn’t fully featured as I’m having the same behavior as you, though we may both be wrong :slight_smile:
Same issue here (also a Nix-beginner). And no related issues found in the extension’s repository
The linting job seem to be in linter.js. But it currently uses nix-instanciate, which seems to only check the syntax and doesn’t enforce keys provided by the Language Server (nixd/nil).
If nixd or nil are able to parse Nix’s options, including their types (possibly the below snippet), it could be possible to enforce a value type check in the editor, in order for the IDE to catch the potential issues earlier. Right? I gave a quick look at the nixd LSP files (but I’m having hard time with C++…)
That would be a useful feature! I’d be glad to know more about this.
I had some promising (but not perfect) results when following some information from the nixd github repo.
try this:
    "nixpkgs-fmt",
    "nixfmt",
    "treefmt",
    "--stdin",
    "{file}",
    "nix",
    "fmt",
    "nixd": {
      "formatting": {
        "command": [
          "nixpkgs-fmt"
      "nixpkgs": {
        "expr": "import (builtins.getFlake \"/path/to/flake.nix\").inputs.nixpkgs {}"
      "options": {
        "home_manager": {
         /*the below is for those who directly integrate their home manager into nixos, what others use is for stand alone home manager*/
          "expr": "(builtins.getFlake \"/path/to/flake.nix\").nixosConfigurations.<name>.options.home-manager.users.type.getSubOptions []"
        "nixos": {
          "expr": "(builtins.getFlake \"/path/to/flake.nix\").nixosConfigurations.<name>.options"
also, if using flakes, add this to your configuratiion.nix:nix.nixPath = [ "nixpkgs=${inputs.nixpkgs}" ];
still doesn’t fix everything for me, but I hope this helps someone find out whats going on.
the nixd repo also says we should report an issue if something like this happens with nix IDE, so we should all do that…
In theory. nixd doesn’t implement this, because doing so would require evaluating the nixpkgs repository, which is extremely slow. All of the NixOS option types - including their type checks - are implemented in nix, in the nixpkgs repository.
There’s nothing wrong with your configurations, this is simply not currently supported.
This ultimately comes down to the NixOS != nix problem, i.e., NixOS is implemented in nix, but nix does not directly support it, and the language is not per-se designed to allow for stuff like custom type implementations. This leads to poor error reporting when using NixOS, as well as poor diagnostics in language tooling when working on NixOS.
This thread did make me wonder if a third-party NixOS module evaluator could be implemented. The errors would technically be a heuristic, because it’s impossible to assert anything outside of a specific file scope, but it should at least be possible to figure out the type of most options (individual modules can define custom types, so this would not work everywhere), and match whether what’s being set is correct. It’d get messy with having to evaluate e.g. lib.mkMerge, though, and there would need to be additional heuristics to check if you’re in a package definition or a module definition. And which module system… And nixpkgs commit…
How long until we fork a nixos-nix with special type management? :stuck_out_tongue:
As for trying to parse empty files, you should probably report that to the plugin author. nixd works fine in emacs land, I’d guess the plugin doesn’t fully comply by the LSP spec.
Also see
Which I still haven’t figured out
