I have home-manager set as a NixOS module, this means running nixos-rebuild switch --sudo additionally activates home-manager services for each user
The issue being: When home-manager activation fails, the switch still happens !
Is there a way to make it so a failing activation also stops the switch ?
Confirmed by running nixos-rebuild switch --sudo, having HM fail, and then havind a new line in nixos-rebuild list-generation, plus this is also hinted at by:
warning: the following units failed: home-manager-qube.service
If the action is switch or boot, the bootloader is updated first so the
configuration will be the next one to boot.
So for a single nixos-rebuild boot/switch command, you’ll always get the new boot entry before knowing whether HM is all green.
One approach might be to (1) run nixos-rebuild test which activates the new system without changing the boot stuff. You get a temporary system profile, not a new numbered generation. If everything looks good, (2) run nixos-rebuild switch/boot as normal. If that’s too much typing, you could make your own aliases, or a script that does step 1 then pauses and waits for you to check and hit enter before step 2, gates the switch on systemctl --failed, etc.
I don’t mind the boot entry as much, is there a way to make the switch throw an error code ? boot couldn’t as you explained, but switch and test should be able to
Not out of the box as far as I know. A small wrapper checking systemctl --failed (or systemctl status on specific units you care about) after the switch is the most direct way to get there that I’m aware of.
Edit: Wait, there’s one thing. You can customize activationScripts if you need to. Same basic method as the wrapper above, except a nonzero exit code from the activation script itself I believe will get a nonzero out of nixos-rebuild. Those are also run on boot, so don’t go too crazy with them.
