Hey everyone, I could really use some help with a strange issue I’ve been facing with my GPU.
About 6 months ago, I bought a brand new Gigabyte RX 7700 XT OC (with the box, sealed). The performance has generally been solid, with good temps (never exceeding 55°C under load), but I’ve been experiencing bizarre visual glitches in a few games — and only under certain graphics settings.
Here are some examples:
The Quarry: When SSAO is enabled, I see rapidly flashing colored dots and black squares. These glitches get worse when lowering graphics settings to Medium or Low. Disabling SSAO completely eliminates the issue.
Horizon Forbidden West: I notice colored lines around the edges of some characters.
A Plague Tale: Requiem: Flashing green pixels appear, but only when “Resolution Optimizer” is set to Quality. The artifacts disappear when set to Ultra Quality.
Call of Duty Warzone: At certain graphics presets, weird flashing colored edges appear on staircases.
What’s strange is that the problems seem entirely dependent on specific graphics settings. Also, when I tested The Quarry using my old CPU’s integrated graphics, the SSAO setting caused no issues at all, which makes me more suspicious of the RX 7700 XT itself.
So far, I’ve tried:
Clean reinstalling Windows multiple times
Using DDU and AMD Cleanup Utility to completely remove and reinstall GPU drivers
Monitoring temps (Hotspot maxes around 85°C, VRAM around 70°C — which seems within normal range)
Attempting to flash or check the BIOS of the GPU with AMDVBFlash, but I get an error: 0xFFFFFF: Fail - Unknown when trying to read the ROM
At this point, I’m really not sure what else to try. Could this be a hardware issue? A BIOS mismatch? A driver-level problem with how the card handles specific shaders or effects like SSAO?
Has anyone experienced anything remotely similar with the RX 7700 XT — especially in any of the mentioned games? Any advice or troubleshooting steps would be greatly appreciated.
,Here are some link of video clips and pictures from my computer screen that show the problem more clearly for those who may be interested. :
Thanks in advance for any help!
