I tried to install qmk via nix-env on my M1 MacBook just now, and I’m seeing a behaviour I can’t quite understand:
$ nix-env --version
nix-env (Nix) 2.13.3
$ nix-env -iA unstable.qmk
installing 'qmk-1.1.2'
error: Package ‘avr-stage-final-gcc-wrapper-8.5.0’ in /nix/store/1mcdyrcp9s1i5pxvn1cslvvkc0ndd495-unstable/unstable/pkgs/build-support/cc-wrapper/default.nix:613 is not available on the requested hostPlatform:
hostPlatform.config = "aarch64-apple-darwin"
package.meta.platforms = [
"i686-cygwin"
"x86_64-cygwin"
"x86_64-darwin"
"i686-darwin"
"aarch64-darwin"
"armv7a-darwin"
"i686-freebsd13"
"x86_64-freebsd13"
"x86_64-solaris"
"aarch64-linux"
"armv5tel-linux"
"armv6l-linux"
"armv7a-linux"
"armv7l-linux"
"i686-linux"
"m68k-linux"
"microblaze-linux"
"microblazeel-linux"
"mipsel-linux"
"mips64el-linux"
"powerpc64-linux"
"powerpc64le-linux"
"riscv32-linux"
"riscv64-linux"
"s390-linux"
"s390x-linux"
"x86_64-linux"
"aarch64-netbsd"
"armv6l-netbsd"
"armv7a-netbsd"
"armv7l-netbsd"
"i686-netbsd"
"m68k-netbsd"
"mipsel-netbsd"
"powerpc-netbsd"
"riscv32-netbsd"
"riscv64-netbsd"
"x86_64-netbsd"
"i686-openbsd"
"x86_64-openbsd"
"x86_64-redox"
package.meta.badPlatforms = [
"aarch64-darwin"
, refusing to evaluate.
a) To temporarily allow packages that are unsupported for this system, you can use an environment variable
for a single invocation of the nix tools.
$ export NIXPKGS_ALLOW_UNSUPPORTED_SYSTEM=1
Note: For `nix shell`, `nix build`, `nix develop` or any other Nix 2.4+
(Flake) command, `--impure` must be passed in order to read this
environment variable.
b) For `nixos-rebuild` you can set
{ nixpkgs.config.allowUnsupportedSystem = true; }
in configuration.nix to override this.
c) For `nix-env`, `nix-build`, `nix-shell` or any other Nix command you can add
{ allowUnsupportedSystem = true; }
to ~/.config/nixpkgs/config.nix.
This is the first time I’m seeing this, and I don’t think I ever heard of aarch64-apple-darwin before. What is the difference between aarch64-apple-darwin and aarch64-darwin? Are they really incompatible? Could I manually override my hostPlatform to be aarch64-darwin again?
All I could find on this is an old GitHub Issue about nix supporting aarch64-darwin. aarch64-apple-darwin is only mentioned once with regards to LLVM. Might that be related to my issue here?
