error:
at /builtin/derivation.nix:9:12: (source not available)
… while evaluating derivation 'nixos-system-pi-24.05.20240509.f1010e0'
whose name attribute is located at /nix/store/asymc3nsl739p1wwr0w6xbjnqs3qb94p-source/pkgs/stdenv/generic/make-derivation.nix:331:7
… while evaluating attribute 'buildCommand' of derivation 'nixos-system-pi-24.05.20240509.f1010e0'
at /nix/store/asymc3nsl739p1wwr0w6xbjnqs3qb94p-source/nixos/modules/system/activation/top-level.nix:53:5:
52| passAsFile = [ "extraDependencies" ];
53| buildCommand = systemBuilder;
54|
error: The option `hardware.deviceTree.filter' has conflicting definition values:
- In `/nix/store/lwlj29my7yhn41indi3m5bvcrrc398yg-nixos-hardware/nixos-hardware/raspberry-pi/4/modesetting.nix': "bcm2711-rpi-4*.dtb"
- In `/nix/store/kx8p0ah21w6xg6pqkb9ll83jxpkyqw5x-source/configuration.nix': "*rpi-4-*.dtb"
Use `lib.mkForce value` or `lib.mkDefault value` to change the priority on any of these definitions.
The first line says that the mention file sets the filter to “bcm2711-rpi-4*.dtb” and the second line is your file.
For this to be true you have to have also set options.hardware.raspberry-pi."4".fkms-3d.enable to true (somewhere).
I suggest just removing the manual setting of the filter.
building '/nix/store/xh7awwwwdpr7v7hpgi0ngr5lgxir8bhy-device-tree-overlays.drv'...
./broadcom -> /nix/store/g1vryd1fi3rnp14lclkpvviq26lnlfk3-device-tree-overlays/./broadcom
'./broadcom/bcm2711-rpi-4-b.dtb' -> '/nix/store/g1vryd1fi3rnp14lclkpvviq26lnlfk3-device-tree-overlays/./broadcom/bcm2711-rpi-4-b.dtb'
'./broadcom/bcm2711-rpi-400.dtb' -> '/nix/store/g1vryd1fi3rnp14lclkpvviq26lnlfk3-device-tree-overlays/./broadcom/bcm2711-rpi-400.dtb'
Applying overlay rpi4-cma-overlay to bcm2711-rpi-4-b.dtb... ok
Applying overlay rpi4-vc4-fkms-v3d-overlay to bcm2711-rpi-4-b.dtb... ok
Applying overlay rpi4-cpu-revision to bcm2711-rpi-4-b.dtb... ok
Applying overlay audio-on-overlay to bcm2711-rpi-4-b.dtb... DTOVERLAY[error]: can't find symbol 'audio'
error: builder for '/nix/store/xh7awwwwdpr7v7hpgi0ngr5lgxir8bhy-device-tree-overlays.drv' failed with exit code 1
error: 1 dependencies of derivation '/nix/store/rr5fm2c4y1yqk6fgdgmaj4xhbjgqb1fw-nixos-system-pi-23.11.20240604.a2e1d04.drv' failed to build
