Why does this code work without rec {}?
I’m talking about this code:
If it’s not obvious, it’s basically:
  packages = {
    linux_5_10 = ...;
    linux_5_15 = ...;
  packageAliases = {
    linux_default = if stdenv.hostPlatform.isi686 then packages.linux_5_10 else packages.linux_5_15;
The things inside packageAliases can somehow access packages without rec {}.
Where it should’ve been:
rec {
  packages = {
    linux_5_10 = ...;
    linux_5_15 = ...;
  packageAliases = {
Fix point magic:
linux-kernels.nix starts with with linuxKernel;. This means that packages will be resolved to linuxKernel.packages.
all-packages.nix defines linuxKernel as linuxKernel = recurseIntoAttrs (callPackage ./linux-kernels.nix { });. This means that the linuxKernel argument in linux-kernels.nix is whatever linux-kernels.nix itself returns.
This basically simplifies to:
$ cat linux-kernels.nix
linuxKernels:
with linuxKernels;
  a = 1;
  b = a + 1;
$ cat test.nix
let lib = import <nixpkgs/lib>;
lib.fix (import ./linux-kernels.nix)
$ nix-instantiate --eval --strict test.nix
{ a = 1; b = 2; }
