WiFi + Bluetooth card issues?
(Discord)
I do not know where to ask for support on this issue, so I’ll just go to the distro specific forum(s).
Most of the time the WiFi card in my laptop works fine, but for a while, I’ve had to open my laptop and take out the battery for a bit (once every, say, 2 months) in order for my WiFi card to work again. Now it just straight up works for 5 minutes and then it dies. My dmesg logs.
Is this hardware failure? Is this something with the kernel? Where should I go from here?
Looks like hardware failure to me. You could try a BIOS/firmware upgrade.
How could I confirm or deny this?
I will try this again. Last night when I tried to upgrade the UEFI it failed to recognize the file off of the official website as valid
I was eventually able to upgrade the UEFI, but the problem still persists. At first glance, the logs seem to look the same:
