My system is ASUS TUF GAMING A15 (FA506IC). Its network controller is MT7921. nix (Nix) 2.28.3
Issues
After connecting to WiFi with either wpa_supplicant/iwd/networkmanager, my system will either just lose connection and waybar freezes or kernel panics with just capslock blinking.
While shutting down or rebooting, any WiFi related services will prevent the system from shutting down, sometimes saying mt7921 driver own failed. Maybe kernel panics too. If I wait long enough, the screen turns black with no sign of the thing ever turning off. I have to force shutdown every time.
I’m not sure what kernel version exactly is this happening on but I’ve tried a few of 6.x versions available in nixpkgs and I found problems in all of them that I’ve tried.
I’ve tried searching up the problem and found related issues in bug tracker for other distribution but they’re seems to be a bit different each time. They seems to solved it usually by downgrading linux version which doesn’t seems to work for me.
I’ve been dealing with problem for awhile now. I think my WiFi works after I reinstalled NixOS but the problem came back after I did a nixos-rebuild.
So with all the problem, I think this is probably caused by a bug in some kernel module. Any ideas?
If your suspicion is correct there is not much you can do besides maybe reporting the bug upstream, but if it’s persisted for this long it sounds like that module is practically abandoned. That, or it may also just be hardware failure…
I have hibernated in the past and did nixos-rebuild at some point but I don’t have any issues with wifi then. I’ve make sure to turn off fast boot before removing window and wipe the disk.
I remembered that I actually found a patch in the mailing list related to this problem before but I unfortunately can no longer find it for some reason. It seems to be something not releasing the driver causing deadlock.
I find it unlikely that a kernel bug this severe would stick around for this long, so yeah, I’d also suspect a hardware issue here. If fiddling with BIOS doesn’t change anything, return the laptop.
I now finally get to try Linux 6.15.1 and some of the problems had been fixed.
The laptop no longer freeze or panics but the wifi continues to failed after a while.
My laptop’s bios do not have an APM options so I’m not sure what other option to try.
I still doesn’t think the problem is with the hardware since I’ve been using Windows and then Linux on this laptop for years… so I might be out of warranty too.
So after some more careful observation, I believe I found out that:
There aren’t any issue on a stable Wi-Fi but the problem only occur after Wi-Fi temporary disconnected, like when I turn off the router.
After the Wi-Fi disconnected and if there aren’t any other Wi-Fi that the system can’t detect, the kernel panics (If not panic, almost everything that require internet connection is freezed, like they’re waiting for something), or else the system continue to works but I have to switch network to continue internet connection.
I cannot select the previous Wi-Fi network, as they simply don’t show up, until I do a hard reset (Battery off for a few minutes) or turning the laptop off overnight.
I have recently been living in other place temporary and there are barely any problem, there are a couple of freezes every few weeks. But after I got home, the problem to the came back to about the same frequency as previously but I can restart a few times and the problem goes away temporary. I wonder if it is possible for others to reproduce this with an unstable wifi or whatever it is doing at my house?
